Question about Cannon Speed N Temp Sensor
Speed and temp. sensor will not work - Cannon Speed N Temp Sensor
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
Tip
Mack Fault Codes List
FAULT CODE IDENTIFICATION TABLE - VMACIII - 1998 & NEWER
1-1 Engine Oil Pressure Sensor
1-2 Barometric Pressure Sensor
1-3 Fuel Temperature Sensor
1-4 Ambient Air Temp Sensor
1-6 Starter Input
1-7 Engine Coolant Level
1-8 (ASET CEGR) Estimated % Fan Speed
1-10 Aux. Cooling Relay Output
2-1 Engine Coolant Temp Sensor
2-2 (ASET IEGR) Boost Air Pressure Sensor
2-2 (ASET CEGR) Boost Air Pressure
2-3 Intake Air Temp Sensor
2-4 Trans Oil Temp Sensor
2-5 Front Drive Axle Oil Temp Sensor
2-6 Rear Drive Axle Oil Temp Sensor
2-7 Engine Oil Temp Sensor
2-8 (ASET CEGR) Combustion Air Temperature
2-9 (ASET CEGR) Combustion Air Temp Sensor
3-1 Exhaust Temperature Sensor
3-2 Engine Speed Sensor
3-3 Redundant Engine Speed
3-4 Engine Position Sensor
3-5 Engine Brake Output #1
3-6 Engine Brake Output #2
3-8 Trans Splitter Position
3-10 (ASET CEGR) Engine Brake Output #3
4-1 Vehicle Speed Sensor (VSS)
4-2 Fan Clutch Output
4-3 Auxiliary Output #1
4-4 Auxiliary Output #2
4-5 (ASET IEGR) Wastegate Output
4-5 (ASET CEGR) VTG Position Sensor
4-6 Tachometer Output
4-7 Speedometer Output
4-8 Customer Defined Statement
4-9 (ASET CEGR) EGR Valve Mechanism
5-1 Throttle Position Sensor
5-2 Throttle Position Sensor Reference Voltage
5-3 Engine Shutdown Lamp/Alarm
5-5 Electronic Malfunction Lamp
5-6 Spare Relay #3
5-7 Engine Oil Level
5-8 (ASET CEGR) EGR Temperature
5-9 (ASET CEGR) EGR Mass Flow
6-1 Fuel Level
6-2 (ASET CEGR) Turbocharger Speed
6-3 J1708/J1587 Link
6-4 J1939 Link
6-5 All Communication Lost - Engine Shutdown
6-6 Fuel Control Module
6-7 Power Relay
6-8 J1939 Link
6-9 Other ECU Affecting Operation
7-1 Service Brake Switch
7-2 Parking Brake Switch
7-3 Speed Control SET Switch
7-4 Speed Control RESUME Switch
7-5 Battery / Alternator Voltage
7-6 Switched Voltage
7-7 Exhaust Temp Reference
7-9 VTG Actuator
8-1 Electronic Unit Pump #1
8-2 Electronic Unit Pump #2
8-3 Electronic Unit Pump #3
8-4 Electronic Unit Pump #4
8-5 Electronic Unit Pump #5
8-6 Electronic Unit Pump #6
8-9 Solenoid Boost Voltage
9-1 Transport Protocol
9-2 Power Reset Without Key Switch
9-3 (ASET CEGR) Aftercooler Outlet Temperature
9-5 (ASET CEGR) Compressor Discharge Temp
9-8 (ASET CEGR) Auxiliary Output Device #1
9-9 (ASET CEGR) Auxiliary Output Device #2
9-10 (ASET CEGR) Auxiliary Output Device #3
10-1 (ASET CEGR) Internal Sensor Voltage
10-2 (ASET CEGR) 5 Bolt Supply
10-3 (ASET CEGR) Sensor Supply Voltage #1
10-4 (ASET CEGR) Sensor Supply Voltage #2
10-5 (ASET CEGR) Fuel Filter Differential Pressure
10-6 (ASET CEGR) Fuel Delivery Pressure
10-7 (ASET CEGR) Odometer Save Area Failure
10-8 (ASET CEGR) GPS Position Data Not Received
10-9 (ASET CEGR) Watchdog Timer Reset
source
on Dec 20, 2016 | Cars & Trucks
Choke not working in the morning
1998 should be fuel injected the choke is a cod start system containing the engine coolant temp sensor. intake manifold temp sensor idle speed control motor.
Nov 14, 2013 | 1998 Dodge Dakota
Speedometer and Odometer not working at times, matches with engine heat cycle
Your vehicle speed sensor is mounted in the transaxle housing which is also subject to heating and cooling. The wiring harness to and from the speed sensor is also subjected to engine heating and cooling. Anybody that knows anything about electrical circuits can tell you that an electrical circuit's worst enemy is heat. You need to diagnose the vehicle speed sensor circuits like the code is TELLING you to do.
Jun 02, 2012 | 1998 Ford Windstar
My c6 in bronco starts off in 2nd gear performs ok every other way.
P0700 Transm.Contr.System Malfunction 17084
P0702 Transm.Contr.System Electrical 17086
P0703 Torque Converter/Brake Switch B Circ Malfunction 17087
P0705 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction 17089
P0706 Transm.Range Sensor Circ Range/Performance 17090
P0707 Transm.Range Sensor Circ Low Input 17091
P0708 Transm.Range Sensor Circ High Input 17092
P0710 Transm.Fluid Temp.Sensor Circ. Malfunction 17094
P0711 Transm.Fluid Temp.Sensor Circ. Range/Performance 17095
P0712 Transm.Fluid Temp.Sensor Circ. Low Input 17096
P0713 Transm.Fluid Temp.Sensor Circ. High Input 17097
P0715 Input Turbine/Speed Sensor Circ. Malfunction 17099
P0716 Input Turbine/Speed Sensor Circ. Range/Performance 17100
P0717 Input Turbine/Speed Sensor Circ. No Signal 17101
P0721 Output Speed Sensor Circ Range/Performance 17105
P0722 Output Speed Sensor Circ No Signal 17106
P0725 Engine Speed Inp.Circ. Malfunction 17109
P0726 Engine Speed Inp.Circ. Range/Performance 17110
P0727 Engine Speed Inp.Circ. No Signal 17111
P0730 Gear Incorrect Ratio 17114
P0731 Gear 1 Incorrect Ratio 17115
P0732 Gear 2 Incorrect Ratio 17116
P0733 Gear 3 Incorrect Ratio 17117
P0734 Gear 4 Incorrect Ratio 17118
P0735 Gear 5 Incorrect Ratio 17119
P0740 Torque Converter Clutch Circ Malfunction 17124
P0741 Torque Converter Clutch Circ Performance or Stuck Off 17125
P0748 Pressure Contr.Solenoid Electrical 17132
P0750 Shift Solenoid A malfunction 17134
P0751 Shift Solenoid A Performance or Stuck Off 17135
P0752 Shift Solenoid A Stuck On 17136
P0753 Shift Solenoid A Electrical 17137
P0756 Shift Solenoid B Performance or Stuck Off 17140
P0757 Shift Solenoid B Stuck On 17141
P0758 Shift Solenoid B Electrical 17142
P0761 Shift Solenoid C Performance or Stuck Off 17145
P0762 Shift Solenoid C Stuck On 17146
P0763 Shift Solenoid C Electrical 17147
P0768 Shift Solenoid D Electrical 17152
P0773 Shift Solenoid E Electrical 17157
P0790 Normal/Performance Switch Circ Malfunction 17174
Dec 20, 2010 | 1985 Ford Bronco
Hi sir, i want some details related to the gear
Dec 20, 2010 | 2006 Renault Fuego
1995 Pontiac TransAm w/5.7 l v-8. Overheats at slow speeds because the elec. fan does not start until the engine temp reaches 220 or more. Could I install a toggle switch w/ a diode in the coolant temp...
I think 220 is the proper temperature for the fan to turn. 220 is too hot and that's why it is turning on but should never have to ideally. What your car likely needs is new coolant and a new thermostat. I recommend a 185* thermostat.
Dec 02, 2010 | 1995 Pontiac Firebird
Replaced complete fan assembly Two sensors. Fan
is the temp gauge working? sounds like coolant temp sending unit... or a possible engine coolant temp sensor or ect sensor.
Aug 05, 2009 | 1996 Ford Mustang
Speedometerand temp gauge quit
Check fuse panel. Also the temp sensor might be bad on motor. Also check the connection on trans, on pick up sensor of speed. Speed sensor might also be bad???? Check your ground on the motor & firewall. That can be a proble also,
Nov 13, 2008 | 1993 Saturn SL2
Cannon Speed N Temp Sensor Logo
24 people viewed this question
Top Cannon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cannon Boating Expert? Answer questions, earn points and help others
