Question about Brother NX-400
Balance wheel is totally jammed
Machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel. I have tried looking in the machine, but I can't find any thread jammed.
  • katie_lafaw
    katie_lafaw Feb 07, 2012
    I have the exact same problem! Was just sewing a straight line in some cotton (a very very loooong line) and suddenly the machine completely jammed. I removed the thread spool and bobbin with no issues, and can't find a jammed thread ANYWHERE. But the wheel is stuck! Help!
  • Jimmie Sill Aug 08, 2014
    TRY TO REMOVE THE BOBBIN ASSEMBLY AND TURN IT. IF IT TURNS YOU PROBABLY HAVE THE WRONG BOBBIN. ALSO, MAKE SURE IT IS INSTALLED SO THE ASSEMBLY CAN BE LATCHED PROPERLY. IF THIS DOESN'T WORK YOU MAY NEED TO ADJUST THE HANDWHEEL. FOR THIS I WOULD SUGGEST YOU TAKE IT TO YOUR LOCAL SHOP. ALSO, CHECK YOUR NEEDLE AND SEE IF IT IS MAKING CONTACT WITH THE HOOK (POINTED THING UNDER THE BOBBIN). IF IT IS THEN EITHER YOUR NEEDLE IS INSTALLED BACKWARDS OR IS CROOKED. IF THIS DOESN'T FIX IT THEN YOUR HANDWHEEL MAY NEED TO BE ADJUSTED OR THE OLD GREESE REMOVED AND NEW GREASE INSTALLED. THESE ARE THE MOST LIKELY PROBLEMS.
Posted on Nov 17, 2008
Janome JF 1014 sewing machine, needle wont move, everything seems to be jammed. Manual wheel wont move.
can only guess that the timing is off. needle and bobbin case is jammed and you need to take it t a repair shop
Mar 04, 2017 | Sewing Machines
Tip
Sewing machine balance wheel stops.
Hold the wheel with one hand, turn the stop motion screw towards you. Place both feet upon the treadle and turn the balance wheel towards you at the same time allowing the feet to move freely and lightly with the treadle. Continue this until everything moves freely and easily. Do this until the machine can re-start without the balance wheel turning in the wrong direction.
Then tighten the balance wheel. Then place cloth under the presser foot then lower presser foot with the lever.
on Jan 18, 2010 | Sewing Machines
Balance wheel doesn't turn
Don't force it. open up under the presser foot and the bobbin area.... pick out any threads.
Sep 01, 2012 | Janome L-344 Mechanical Sewing Machine
I have a new machine, using for the second time. After filling bobbin, handwheel became completely stuck. Removed bits of thread from needle plate and reinserted bobbin. Can't do anything now because...
There is till thread jammed in the racway itself, force the balance wheel backwards and you may free it off that way otherwise take the raceway out.
Sep 17, 2011 | Sewing Machines
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
Needle doesn't move, the balance wheel is very hard to turn
Sounds like it is jammed with thread or fabic. Totally rethread your machine and clean out your bobbin area. Then try turning your wheel towards you. If, you do not have your manual to check, go to www.sewingmanuals.com and download one for $10. If that doesn't do it, all you can do is take it in for service.
Sep 19, 2010 | Janome L-344 Mechanical Sewing Machine
My Pfaff 1211 was working and all of a sudden it
Your hook where your bobbin case goes in are most likele jammed with cotton. give it some oil and turn your handwheel backwards gently. Look if you see any cotton jammed and remove it
Jan 20, 2010 | Sewing Machines
Brother NX-400 Logo
1,504 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
