Question about Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio
Out of the blue one of my cobra microTALK LI6000 won't turn on. It is not the battery because the other radio works and I switched batteries and that did not resolve issue.
Agent Ken
  • 250 Answers
SOURCE: transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 21, 2008
kditterline
  • 127 Answers
SOURCE: I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Posted on Jul 16, 2009
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
keithkalish
  • 146 Answers
SOURCE: I cannot get one of the radios to turn on. I've tried a good battery to no avail
Your fuse is blown, not sure if you can replace it.
Some of our radios you have to take quite a bit apart to get at the fuse and replace it.
Posted on Sep 16, 2009
Ironfist109
  • 3018 Answers
SOURCE: cobra pr 3850wx bought new NiMh 800mAh 1.2v
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
Posted on May 23, 2011
Cobra microtalk
Please mesure the battery voltage first...then get the service manual and check if there is an smd fuse right next to power pushbutton....please inform me for any progress...thnx..
Feb 24, 2014 | Radio Communications
I have the Cobra micro Talk LI6000-2 (14 Channels) 2-Way Radios and one turns on and charges and the other will not turn on for anything. They will not charge unless turned on and on the charger; so one is...
  • The fact that these turn on while on the charger is an indicator that the batteries are just that far gone. Depending on how much you like these radios vrs the cost of a new set is something to think about.
  • This link is where you can get a reliable battery replacement.
http://www.batteries.com/battery/cobra/103-0001-1-battery_R-414884-205946.html
  • I use a newer Midland talk around for camping, hiking etc. The thing I always look for in a talk around radio is if the manufacturer battery goes bad or runs dry can I use some batteries at home with it? I like the fact I can put 4AA batteries of the shelf in my radio in an emergency. And when the stock battery gores kaput, I can use some AA rechargeable batteries I already have at home and save on replacing the battery or radio. Something to think about should you decide to get a different radio set.
Regards, Tony
Apr 27, 2011 | Cobra microTALK LI6000-2 (14 Channels)...
THE RADIO NOT TURN ON
hello have you checked the batteries you will need to charge them in the cradles for 4hrs leave the radios turned off while charging ,other solution when charging turn radio on to see does it work ,the batteries might need replacing goodluck
Mar 29, 2011 | Cobra microTALK LI6000-2 (14 Channels)...
Need Batteries for Cobra LI6000-2xz
most use rechargable battereys from the shops
May 08, 2009 | Cobra microTALK LI6000-2 (14 Channels)...
Apr 20, 2009 | Cobra microTALK LI6000-2 (14 Channels)...
Cobra microtalk Li16000-2 (14 channels)
Dear sir,
Its important to remove batteries from circuit if u are shutting down the unit for long period . Your battery is in deep discharged mode now , & charging is not so easy , or consider it dead as LI-ion batteries have a specific life .U can find the same in ebay usa website available between 7~12 USD per pair.
Regards
raj
Feb 11, 2008 | Cobra microTALK LI6000-2 (14 Channels)...
Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio Logo
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
