Question about Cell Phones
It's running 10min slow - Cell Phones
How long does it take for IOS 8.0.2 to download to iPad?
depends on your internet connection speed...
with a slow broadband connection it is around 10min.
preferably done with iTunes on a mac computer:
long-ios-8-0-2-download-ipad-opcpacmo2cg3uwkbeputuwxv-1-0.jpg long-ios-8-0-2-download-ipad-opcpacmo2cg3uwkbeputuwxv-1-2.jpg long-ios-8-0-2-download-ipad-opcpacmo2cg3uwkbeputuwxv-1-5.jpg
Sep 26, 2014 | Apple iPad Tablets & eReaders
Replaced egr valve codes still on?
try unhooking the battery for 1 or 2 min then let sit for 8hrs start turn on all heat front and back run at highway speed for about 10min then city run for 10min let idle 10 min this will reset the comp and codes should go away
Jan 29, 2013 | 2006 Chevrolet Uplander
After 5-10min driving around the truck struggles to run smooth. as i come to a stop or even slow down 5 out 0f 10 times it stalls out. the restarts is good, but still struggles to run. I have to rapidly...
Check the TPS Sensor on throttle body (throttle position)
Also the Air Idle Control Solenoid at the base
of throttle body, on side
Spark plugs strangely make a difference on the dakota,
clean rotor & cap
There is no timing adjustment
Never move your distributor,it is for
injector timing
Jun 12, 2011 | 1988 Dodge Dakota
Grand am wont start. it is turning over tho. i tried the security fix (leaving it on for 10-20 mins, then off and trying) but it still won't start.
Hello: Try this, Turn key on, try to start, let k/switch come back to run, let set for 10min(security light out) turn key off 10sec, turnkey back on let set 10min, turn key off 10 sec, turn key on let set 10min. turn key off 10sec. turn key on start car if it doesn't start and the security light is flashing you have a passlock problem and it will require a new lock cylinder assembly and the above learn procedure.
Jan 27, 2011 | 2001 Pontiac Grand Am SE
Runs for 10min.thenpuffs 3 times,white smoke,thenPOPS BREAKER
good day, you may have a problem on the circuitry, might be grounded wires, have it checked. hope this helps, have a nice day
Feb 08, 2010 | Reddy Heater-30-55,000 BTU Variable
Clock and timer on Whirlpool GH7155XHS micro/hood are running slow. Clock loses about 10min/hr and kitchen timer countdown is slow.
I've just fixed a very similar problem with a 10-yr-old NEC microwave oven.
Disconnect AC power, take the top cover off, go through the unit and tighten all screws, particularly those connecting ground wires to the chassis and those fixing major components like the power transformer and magnetron to the chassis.
May 28, 2009 | Whirlpool GH7155XHS Microwave Oven
Refrigerator not cooling - shuts off every 5-10min
You need a new start relay. it is attached directly on the compressor where the wires go in. Take it off and shake it if a box of matches....
May 10, 2009 | Refrigerators
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
