Question about Nintendo Video Game Consoles & Games
Not connecting to the internet for netflix - Nintendo Video Game Consoles & Games
I have a new house next door to my previous one that I had Netflix. I hooked up to internet have cable etc but can't get Netflix on my tv please help!
hi Jonel.
see if this helps you out.
Method 2 Smart TV
  1. Determine if your TV is a Smart TV. Smart TVs connect to your home network, and can run media streaming apps such as Netflix. ...
  2. Connect your Smart TV to your home network. ...
  3. Open your Smart TV apps. ...
  4. Select the Netflix app. ...
  5. Log in with your Netflix account. ...
  6. Browse using your remote.
6 Simple Ways to Watch Netflix on TV - wikiHow
How do you set up Netflix on TV?
Connect your Internet-ready television either with an Ethernet cable or wirelessly to your router. Follow the steps on the television to connect it wirelessly. 2. Select theNetflix Apply from the menu on the television screen.
How to Set Up Netflix Streaming for a TV ' Chron.com
smallbusiness.chron.com/set-up-netflix-streaming-tv-27369.html Search for: How do you set up Netflix on TV?
if this does not help go to this link might help you.
how to get netflix on my tv Google Search
Nov 26, 2017 | Internet Computers & Internet
I am trying to get on to Netflix , I keep getting the message can't connect I've checked the speed of my internet it is 3.10 Mbps is this enough to connect
hi Janet.
this is all i could find out.
Turn off or unplug your Blu-ray player. Unplug your modem (and your wireless router, if it's a separate device) from power for 30 seconds. Plug in your modem and wait until no new indicator lights are blinking on.
Netflix says 'Unable to connect to Netflix.' - Netflix Help Center
https://help.netflix.com/en/node/57687
How do I fix my Netflix connection?Restart your home networkTurn off or unplug your streaming media player.Unplug your modem (and your wireless router, if it's a separate device) from power for 30 seconds.Plug in your modem and wait until no new indicator lights are blinking on. ...Turn your streaming media player back on and try Netflix again.Troubleshooting Network Connection Issues - Netflix Help Centerhttps://help.netflix.com/en/node/85Search for: How do I fix my Netflix connection?
Why cant I access Netflix?Netflix says 'Can't Connect to Netflix.' It typically points to a network connectivity issue that is preventing your device from accessing Netflix. Follow the troubleshooting steps below to resolve the issue. While in the Netflix app, tap the Menu button ( or )in the upper left corner.Netflix says 'Can't Connect to Netflix.' - Netflix Help Centerhttps://help.netflix.com/en/node/61114Search for: Why cant I access Netflix?
if you need more help go to this link.
Netflix message can connect Google Search
Nov 22, 2017 | Internet Computers & Internet
Directions for activating netflix on a samsung 4 4000 led tv
I had the same problem the bottom line is call Netflix and they can walk you through it
Netflix Customer Phone Number Shortest Wait Best Support
888-638-3549
Feb 06, 2015 | Netflix
How do I watch netflix on tv as I have signed up for netflix on line
Your tv needs to have a connection to the internet. If the tv does not have it, you can use a peripheral like a game system that has internet access. A lot of newer tv's have internet access with direct links to Netflix and other online viewing providers. You can also hook up a computer to your tv with a cable and mirror or extend the display to the tv. Then connect to Netflix through your computer.
Dec 24, 2014 | Netflix
Movie
This is generally because of your internet connection either being too slow to support streaming movies using Netflix or being overburdened by other applications or users on your network using up the available bandwidth. Try taking a look at the attached link to see whether your internet connection can properly handle Netflix. How fast should my Internet connection be to watch Netflix
Mar 27, 2014 | Netflix
Do you have to have cable tv to have netflix?
No, you do not have to have Cable TV in order to get the Netflix service. However, in order to watch Netflix you basically need to have an internet connection preferable of decent speed. You will also need a supported device that will let you watch Netflix.
The internet speed will ultimately determine whether you get quality video output on the device you intended to watch Netflix.
You can watch Netflix on your computer or you can use a device (generally now called a media device) that will allow for you to watch Netflix on your TV.
The Netflix app comes on many different media devices, which you essentially plug to you TV and connect to your home Internet connection.
Newer TV have the Netflix app built in to them as well as Internet. These TVs are referred to as Smart TV.
Right of the top of my head are the following Netflix capable devices Xbox 360, Roku, Wii...
Here are a list of other supported devices on Netflix's Website:
Feb 26, 2014 | Computers & Internet
Netflix wont connect on my apple tv and i'm connected to the enternet
  1. Test the Internet connection on the Apple TV
    1. From the main Apple TV menu, navigate to Trailers.
      • If you don't see Trailers: Select Movies, then In Theaters.
    2. Select any title and click Play. If trailer plays, the device is connected to the Internet.
    3. If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
  3. Disconnect Apple TV from your Netflix Account
    1. Navigate to the main Netflix menu inside the application and click Logout.
    2. Select Yes.
    3. You will be returned to the Apple TV's main menu, at which point the device has been successfully disconnected from your Netflix account. You may select Netflix to sign back in with your account information or connect as a different user.
  4. Troubleshoot your Internet Connection
Oct 23, 2013 | Netflix
Need netflix app for kyros 7042 not kindle
  1. Test the Internet Connection
    Make sure your iPad, kindleor iPod touch has an Internet connection by opening another Internet application or the app store.
    • If you are not able to reach the Internet through your cellular carrier, try a wireless network.
    • If you are not able to reach the Internet through a wireless network, you may having network connection issues.
  2. Check the date and time on your Apple iPad, kindleor iPod touch
    If the date and time of your device is significantly different from the current date and time, you will have a problem playing your video.
    1. Tap the Settings icon on the Home screen.
    2. Tap General.
    3. Tap Date & Time.
    4. Tap Set Date & Time.
      • If the date and time are incorrect, adjust the time until it matches your time zone.
      • Or, tap On/Off toggle to On in the Set Automatically field.
  3. Reinstall the Netflix application
    1. From the main menu, touch and hold the Netflix app on the Home screen until it jiggles.
    2. Tap the X in the top left of the Netflix icon, then tap Delete.
    3. Enter the App Store, search for "Netflix" and select the free Netflix app from Netflix, Inc.
    4. Tap the Install button. You will need to enter your iTunes password to install the app.
    5. Once installed, tap the Netflix icon.
    6. Enter the email and password for your Netflix account and tap Sign In.
Oct 19, 2013 | Netflix
Video Game Consoles & Games Logo
159 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
