Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
When the water line is hooked up to the back of fridge and the line is turned on the refrigerator leaks water out the ice dispensor and does not shut off the flow of water to the fridge.Thus causing it to over flow with water.
  • 50 Answers
The water soliniod maybe clogged with calcium. if you get it loose you can take the plastic hose loos from the icemaker side of the water valve see if it is dripping or running out of there. if alot is coming out maybe getting voltage too long from the icemaker. it will be one or the other.
Posted on Aug 04, 2010
Ice dispensor/water dispensor does not work
trace the 1/4 inch water line from the back of the fridge,and make sure the shut valve is open
Oct 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Water not working but still makes ice
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR49X10173 to keep this from happening again ( comes with instructions ) .
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispensing but also leaking from the back
Pull the fridge out and remove the back panel . Have someone press the water dispensor and watch for the leak . Usually , the plastic line at the water valve breaks off , and removing the broken piece and reinserting the line , fixes it . You may have to remove the 1 screw holding the water valve on , to gain access to remove the broken piece of line . The water valve itself , could also have a hole in it , spraying , due to long period of water pressure . Just replace the water valve , if this is the problem .
Sep 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not coming out of dispensor
two problem one water vale are the line were water come out is frozen the water splashes back and line freezes are water vale leakes
Jun 01, 2009 | Refrigerators
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
Emptying resivoir?
If you shut off the right valve, water to the frige will be cut off. The dispensor may have a small spurt left from the pressure in the lines but it should quickly stop. No water will leak out the back valves since they are shut. Some water from the defrost cycles may be in the lower catch pan by the compressor but that's about it. If you have water off and can still get a full glass out the dispensor... then you don't have the correct valve turned off. Usually, there is a cut off valve in the wall just behind the refer to turn off the water. If you disconnect the hose once water valve is off only the water in the line will drain.
Dec 04, 2006 | Kenmore 54383 Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
