Question about Canon PIXMA iP1800 InkJet Photo Printer
An error is occured when i was trying to print my documents.......... the printer also was not responding at the sme time...........
    Problem Solver:
  • 15 Answers
Probably this problem is caused by some driver files of your printer First of all uninstall your printer and then restart your computer. After that install your printer from starting then your problem will surely be solved.
Posted on Apr 26, 2008
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Printer don't print documents. Status "PHD Life
Dear Diogo,
This error message occurs when the print head life is over. Every print head is designed with a specific life time (it is purely a mechanical device). Once the life time is over you will get this error message.
I recommend you to calibrate the print head, if you have that option in the software or front panel display(if any). Also, you can try using a new set of cartridges (if you printer is ink jet)
Thanks and regards,
Dr Tony.
Apr 14, 2011 | Office Equipment & Supplies
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer not activated-error code 30
Sometimes, you may get printer not activated - error code 30 when you try to print using your printer. It may occur when you try to print a PDF document. Sometimes, your Antivirus scripts block you from generating the document and you may have to face this issue. If you have installed Antivirus software and you have encountered "Printer not activated" error, you need to disable script blocking. If this does not resolve the issue or you do not have installed Antivirus, you need to change the Calyx Document Converter printer settings. If it also doesn't work, you need to reinstall the printer driver in your system.
Jul 12, 2009 | Cannon Office Equipment & Supplies
Epson RX560 problems photo printing
RX 560 a printer error has occured see documentation
Sep 03, 2008 | Epson Printer
Error message 490 mismatch
mismatch occurs when printer paper settings and document page size are not the same, check document page size.check print driver settings.
Nov 21, 2007 | OKI C5200n Laser Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
old marine
old marine
