Question about Proform CrossTrainer Treadmill
Proform EKG Cross Trainer Treadmill-will not operate since it has been moved. When the speed is set, it will start at the set speed and immediately decrease until it stops. Also, the incline will not operate and none of the controls seem to work. You cannot even change from auto to manual. It was fine until it was moved after being purchased used. Any advice or help would be greatly appreciated. Thanks Daryl
  • 9 Answers
Check to see that the speed sensor did not move with the actual relocation of the machine. You may also need to recalibrate the machine so that it can figure out its own speed settings. With the incline not working also that can lead to a bad motor controller and these can go bad with too much moving of a machine - any bumps in the road can cause the electronics to short out if it has been previously used - grounding electricity out of components prior to moving prevents this from happening so that the stored electricity does not discharge with bumps in the road
Posted on Aug 05, 2010
Daryl, we've encountered the same problem. My son had the treadmill @ his house, we brought it home for his brothers to use, and now will not turn on. Were you able to solve your problem? It was working fine 30 min ago, now nothing :(
Posted on Aug 09, 2010
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
My proform 580 runs for 1/2 second, shuts of, and resets and will repeat this as many times that you push the start button
HI,
Your treadmill have problem with the motor control board. The motor control IGBT is faulty thats why its stars at high speed and shuts off immediately by sensing over current drain. The solution is replacing the motor control board or replacing the IGBT on the motor control board. To replace the IGBT you should have a through knowledge in electronics. If you need any more assistance feel free to contact me through FixYa.
AJIN
Jan 19, 2012 | Proform XP 580 Trainer Treadmill
Bought a proform ekg treadmill from a lady on line
Mine did the same thing. I had to take the display apart and clean the contacts on the circuitboard that are underneath the buttons. After I put it back together it has worked perfectly. Mone came from a house where the people smoked and it was the nicotine and tar that was in the smoke that had seeped inside and cause it to stop functioning properly. Well I guess thats why they sold it to me. They likely were not using it anyway. Well I hope this helps
Mar 13, 2010 | Proform 730 Folding Treadmill Model...
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
I have a 1992 Proform CrossWalk Dual Motion Cross Trainer. Motor still works great. There is rubber covering the roller under the moving piece. It has come off on the right side. Can this be replaced?
Really, I have had my crosswalk for over 20 years. I can't complain. I am passing it on to my son and getting a NEW Proform treadmill. Their longevity has sold me.....
Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Aug 10, 2009 | Proform Sport 1000 Folding Treadmill...
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Proform CrossTrainer Treadmill Logo
541 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
