Question about Acer Aspire 5315 Notebook
Hi,i got two problems with this pc which has got just 6 months,first one is that it always gets stuck whatever i do,after a certain time,it stops working,and i have to reboot it all the time,second thing is that the CD-rom is literally too noisy.pls help.thanks
    Habit-Forming:
  • 96 Answers
The cd rom is probably gonna die on it. My friend has an acer she got for christmas and the cd rom died. It is to new to be messing up on you like that call acer have them repair it
Posted on Aug 04, 2010
Fan seems to always be running and when it gets hot it starts making a screeching vacuum like sound
Try blowing out with canned air. It really helps. My PC sounds like engine if I don' t blow out every 6 months or so.
Dec 12, 2012 | HP Computers & Internet
Hi there, car started 2 months back with absolutely no power. 100% till 3ooo rpm. ford diagnosed the catalytic converter was blocked. converter was removed but had low down rpm misfire. replaced all 6...
right there is your problem is converter was removed not replaced u cant remove converter on cars no a days be cause the have oxgen sensor before and after the converter when u take out the convertor the post oxgen sensor will always read rich so computer than trys to adjust timing air/fuel ratio etc . and gets stuck in never ending loop
Jun 02, 2010 | 2006 Ford Ranger
05 Duramax with approxamately 160k. About a year ago the speedometer went haywire jumping all over the place and now is stuck in the corner. A few months later the tach. did the same thing but now it works...
there is a problem with the guage cluster units in these trucks, it has to be changed at the dealer because they need to reprogram the mileage. on certain vehicles, there was actually a recall / hidden warranty, so make sure you look into that.
Dec 10, 2009 | Chevrolet Silverado 2500HD Cars & Trucks
Every so often, after I start my Lenovo T500
It could be anything from a bad keyboard, stuck key, bad port on the motherboard. Since your laptop is only 6 months old it should still be under warranty. Give Lenovo Tech support a call and explain what is happening.
Sep 13, 2009 | Computers & Internet
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
Gateway M-1625 shutting down few times a day
I am havin the same problem at the company i work at. The problem with our machines has to do with the mother boards. But you might want ot check the power supply and make sure it is rated high enough to run your system. Next check/blow out your CPU cooler, and go into bios and see if it is set up to shut off at a certain temp.
Dec 21, 2008 | Computers & Internet
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
Zoom is stuck and reset button not working.
one of the two motor of the lens of your camera is stuck up that why push reset is alway appearing and the power is blinking....only a technician can fix your problem....
Jul 09, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
Acer Aspire 5315 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
