Question about Samsung Digimax S800 Digital Camera
Camera says card locked - Samsung Digimax S800 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 04, 2010
Testimonial: "it worked a treat thank you very much."
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 20, 2010
Camera says card is locked canon powershot sx100
"Card is locked" usually means that the little write protect switch on an SD card has been set to stop the card being written to. Seems unlikely that it would happen to two cards in a row, but it is worth checking this.
Nov 05, 2010 | Canon PowerShot SX100 IS Digital Camera
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
Camera says that my card is locked.
Well, you need to open up the camera to check the SD card slot. This tip may help How to fix a ‘card locked’ problem
Aug 23, 2009 | Canon PowerShot A560 Digital Camera
Camera Says "Card Locked"
It seems you need to open the camera and check the SD card slot.
this tip may help you How to fix a ‘card locked’ problem
Jun 01, 2009 | Pentax K100D Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CARD LOCKED
try puting the lock thing onto Lock. it worked for me
Apr 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
How to unlock camera card--HP M525
Little sliding switch on the side of the SD memory card. Remove from camera, slide switch away from lock position, re-install and you should be good to go.
Mar 07, 2008 | Canon PowerShot A530 Digital Camera
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Card Locked
remove the memory card out of your camera and look to the side of it.. there is a little switch on the memory card that locks the card... try that first it might not be your camera... :) good luck :)
Nov 04, 2007 | HP Photosmart R707 Digital Camera
Samsung Digimax S800 Digital Camera Logo
118 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
