Question about Miele Blue Moon Bagged Canister Vacuum
Miele big blue
Vacuum starts, runs a half a minute then shuts down. checked hoses, replaced bag, hepa filter ??
  • janesbond Apr 28, 2008
    checked the hose, ran it without the hose still cuts off. ooh circuit board$$$$. but i love my blue( not to mention how much it costs) I love to tinker so i'll take it apart and give it a good cleaning with a air compressor. check the electrical plug to the board etc. thanks
  • Anonymous Mar 31, 2014
    how can I replace a split hose on a Miele S7260?
    President:
  • 1,673 Answers
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
Posted on Apr 28, 2008
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Mar 13, 2011 | Miele Vacuums
Tip
How To Maintain a Miele Canister Vacuum
Here's a short Video Presentation that we've put together showing how to replace the vacuum bag, motor filter, and HEPA filter on the Miele Series canister vacuum, as well as how to perform basic maintenance.
How To Maintain a Miele Canister Vacuum Cleaner
on Mar 22, 2010 | Miele Aquarius S5580 Bagged Canister...
Miele canister keeps shutting off when i press + it starts again for short while and off again whats problem i have changed bar but still no good
Was it hot when you pressed "+" button? Did you check the filters(Hepa) or bag if clogged or suction path was blocked? Does it happen after it was cool down? From what you said, it seems none of the above. Only thing I can think of is circuit board. The mortor runs in variable speed. "+" increase the average voltage to the motor thus higher suction. PWM circuit in main pcb may not working correctly.
High priced vacuum cleaner like this shouldn't fail like this but it does. JMO.
Nov 07, 2010 | Miele S548 Bagged Canister Vacuum
Shuts off after a minute or so and comes back on and shuts down in 20 seconds
Sounds like it is over heating do to a dirty filter. Or there is something blocking the air flow in the vacuum.
Jim
Dec 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
My almost new miele Dog and Cat vac keeps telling me the bag is full when it's not (new bag, no clogs)and I have almost no suction. Any ideas?
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Aug 12, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele Revolution Vaccuum cleaner manual
Under the download section is the owners manual. This is for the same series Miele that you have so this manual will have most everything you need to know. The black filter is a charcoal filter, this is good if you want to control the odor but don't have allergies. If you have allergies you might wont to get a HEPA filter. I would recommend changing the filter every 6 months to a year. You need to use the empty filter when you want to use it as a blower. The hose will not fit into the opening with the HEPA or charcoal filter in place. I hope this helps.
https://www.centralvacuumstores.com/item.php?id=4545#
Jan 06, 2009 | Miele Revolution 600 Bagged Canister...
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Miele Blue Moon Bagged Canister Vacuum Logo
431 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
