Electratech manual for a storage heater control panel- not working and it is asking for a code.
2 Suggested Answers
lenwest
  • 150 Answers
SOURCE: hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Posted on Oct 30, 2013
I moved into a flat with newlec NLSH24AN HEATER N NO INSTRUCTION. ..HELP
Hi Sharon,
This should be relatively easy.
You have storage heaters that only take in the hear during cheap rate electricity (at times you cannot change - typically between 00:00 and 07:00 but times vary - ask your electricity supplier).
The controls of an electric storage heater normally consist of two
dials to be found under a flap on the heater.
The input dial, sometimes known as the charge or overnight dial.
This control sets the amount of heat to be stored during the night.
It is best to be set on a seasonal basis: medium for
autumn/spring, high for winter.
If you find that you run out of heat before the end of the day,
and the Input is not on maximum, turn it up to store extra for the
following day.
The Output Dial sometimes known as the room temperature or boost dial.
This dial controls the amount of warm air or convected heat given out during the day. It opens and closes.
Nov 24, 2014 | Heating & Cooling
6700 Rev C? code on control panel?
check to see if red 4 pin plug is plugged in if ok check wire for cut
May 07, 2014 | Jandy Aqualink Rs4 One Touch Control...
Hi, I have a Dimplex DUO500i storage heater and
Oct 29, 2013 | Heating & Cooling
Code 1L on the pad, I flushed with pure venegar. for at least 5 hours the problem persist, help
open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time.
Jan 28, 2011 | Rheem Tankless Water Heater Main Remote...
C4, c7, code on control panel
C7 is communication fault with remote.
C4 is reportedly oxygen sensor problem.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 15, 2010 | Rheem Tankless Water Heater Main Remote...
Over riding switch
You could have a defective thermostat causing the limit control to trip off. Here is the manual!
http://www.insinkerator.com/pdf/POU_ICU.pdf
Copy and paste to your address bar.
Jan 20, 2009 | Emerson InSinkErator W-152 Electric...
Electratech heating system code needed
I know it is a litt;e late to help you but if anyone else has this problem press code then mode 3 times. Then press code once, the display should ask you to confirm this . Press code again as requested. Code should then be removed.
Oct 28, 2008 | Cell Phones
Slimline storage heaters with no switch to turn on/off - how do you turn them on? have taken off the front panel but can see no switch/override - the electric cable comes straight from the wall into the...
The principle of electric storage heaters is that they take in electricity at night through a central time switch (normally owned by the electricity supply company and usually not controllable by the user).
There should then be a main switch/ fuse box to control the heater circiuts, check for such a box and that it is switched on (This would normally be sited near the electricity meter).
There should be an isolator switch next to each heater but from what you say this is not the case.
There should be some controls on each storage heater marked INPUT with a dial from 1 to 6 or similar then another marked OUTPUT or BOOST.
When you have ascertained the fuse box is on and the heater controls are set to maximum you then have to wait overnight for the heaters to warm up.
Oct 09, 2008 | Heating & Cooling
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
