Question about Sharp XL-MP130 CD Shelf System
My sharp XLMP 130 all of a sudden started blinking red four times and then one long one - nothing works??
The problem is with the "power on" relay (RL841) located on the power supply board. Unplug the unit and take off the side panel and top cover. Remove the screws to remove the CD changer. There is a small black rectangular relay just below where the AC cord is soldered onto the PC board. Carefully remove (actually break it off carefully and gently & throw away) the plastic top housing of the relay. Plug in the unit and with a pencil or stick, manually actuate the coil armature while pressing the power on button on the front of the unit. I can almost assure you your unit will return to normal operation. Put it all back together and you're done. The blinking red 4 times followed by a long pulse indicates a power failure. The start up capacitor had drained and couldn't provide enough voltage to pull the relay coil in all the way.
JP
Posted on Feb 20, 2011
  • Kkorhan May 21, 2011
    Thanks for the answer but i still have the same proble. I did exactly what you have instructed and it got turned on, and started working properly. However when i turned it off, it didn't turn on again, giving the same blinking. I'm curious if it is the relay or the capacitor. Any ideas? Also, i may or may not have damaged the coil while trying to open it up (unlikely but possible). Thanks for the answer
  • charlee1a Jun 26, 2011
    Mine does the same thing. That relay applies power to the main power supply by making the AC line connection to the fuse. If you look at the relay, you see 4 terminals that are soldered 2 and 2, this is your normal open contacts of the relay that are closed when the relay is activated. The power on circuitry which is always 'on', that's why the pushbutton turn the thing on, is not functioning properly due to a surge or transient that has gotten into it. If you want the radio to work, making sure the radio is UNPLUGGED, just jumper across those 4 terminals on the relay mentioned above, plug it back in, and the power on button should run it OK. Mine did at least.
Sharp XLMP 130 power button Blinking Red Light - Nothing Works
??? ?????? ??? ??? ?????? ?? ?? ??? ???? ?????? ?? STK 412-490 ?? ???? ???? ???? ????? ?? ?? ???? ?? ??? ??????????? ? STK ?????? ?????? ??? ??? ??? ?? ????? ??? ??????? ???? ???? STK ????? ???? ??? ??? ??? ?? ???? ?????? ??? ???? ??? ?
Jun 08, 2016 | Sharp XL-MP130 170-Watt 5-Disc CD Micro...
My Sharp LC-40CT2E has suddenly gone off. There is no picture and attempts to turn it back on are met with nothing. The sensor light is flashing continuously. The TV is approximately four years old.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Apr 05, 2015 | Sharp Televison & Video
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking in.is the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Looking for the four digit code for my sharp tv
Hello
Four digit universal remote code for Sharp Tv are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and Switch ON the TV by its front panel power ON/OFF switch [NOT BY THE REMOTE CONTROL HANDSET] each time before trying an other code.
Jan 08, 2011 | Sharp 19L-M100 TV
I have a sharp projector RX30X the stand by light still red it doesn't blink and the device doesn't work what's wrong?
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 02, 2010 | Sharp REPLACEMENT LAMP FOR XR30X/30S/40X...
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
Mar 26, 2010 | Sharp XR-11XC Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Sharp projector xr10xl standby light flashing and lamp light on what is wrong?
if it's blinking green, nothing is wrong. it's just cooling. if it's blinking red and the lamp is off, the lamp door is open.
Jan 13, 2009 | Sharp XR10XL DLP Projector
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Sharp XL-MP130 CD Shelf System Logo
849 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
