Question about Mitsubishi WD-52725 52". Rear Projection HDTV
2My Mitsubishi WD52725 displays a blue screen suggesting to check my inputs and says signal is invalid..checked all the connections and all is good there..any suggestions? Thanks in advance, Nick
  • Mitsubishi Master
  • 5,520 Answers
What is your input source and which input cable type? If the source is a PC using a VGA cable, what resolution is the computer sending? 480x640. 800x600, 1024x768, 720x1280 (EIA standard) all at 60Hz are known to work but other modes might not.
If you are using a PC to the HDMI port, it will not work. The only HDMI ports that can connect to a computer will be listed as HDMI/DVI and this TV doesn't have that type of HDMI port.
If you are using any other input source, check try another source or channel. (One of my TVs intermittently finds a digital channel 25-9 and gives that message. We have no clue what station is being found but all the other channels are fine.)
I hope this helps.
Posted on Aug 04, 2010
LCD TV diplays blue screen on all inputs
Nothing on all inputs would suggest the Main AV board not processing signals, if all other functions such as volume, menu access, on and off operate normally the power supply board is probably functioning OK. Have a look at shop jimmy for an idea on price and availability for Mitsubishi LT-46144 Boards and spare parts:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 11, 2015 | Mitsubishi LT-46144 46 in. LCD HDTV
LT-46151 mitsubishi tv, Green light flashes, no picture, back light is on, screen is blue.
If you have any later digital camera or phone with a compatible connector and cable, try connecting this first.
The set may be looking at the wrong input for signal.
Using your remote, check the setup menu to ensure that your source (cable, receiver, etc.) hasn't been accidentally changed.
Often, a blue screen means 'no signal.'
Jun 04, 2015 | Mitsubishi Televison & Video
Ws 65611 will not play HD channels. Screen gets fuzzy like it is trying to focus, then converts to blue screen that states "Check connections or power. The connections for RGBHV or YPrPb invalid" I have...
This model only has one HD input---it has two sets of component inputs on the back and one is marked 480/1080----in the menu it will be the DTV input.
Check to make sure you are not connected to the other component input.
Let me know what happens and let me know exactly where you are connected and what are using for signal.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 28, 2010 | Mitsubishi WS-65611 65" Rear Projection...
HDMI from laptop to Mitsubishi TV worked once and stopped
Sounds like you set HDMI as your primary display device. Try reconnecting to HDMI and use the Mitsubish to make your changes while the laptop is connected. You will need to click the LCD Icon when it shows you the 2 monitors then turn off the HDMI device in that menu. Then select the VGA screen as your primary display device. This can be done with either the displays manager or the optional software supplied with your laptops display. remember to always switch back to your primary video device (LCD) before switching off your PC or laptop since the display resolutions on Hi-Def are completely different than a VGA device as well as the display frequency.
Windows, as well as Bios will prevent your PC from displaying resolutions and frequencies that may damage your Video card.
Mar 14, 2010 | HP Pavilion dv7-1130us laptop
Mitsubishi WD52725 "SNOW" Screen......
try pressing menu 2470 and enter. this will reinitalize the set. if that doesn't work the there is a problem with the chassis. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi Televison & Video
Mistubishi Convergence/video display problem
also check resistor values on the chips and resolder the tuner as this can cause problems as they heat up , then replace any electrolitic capacitors in the video circuts selector ic
i will be back to see what you get
electech
Oct 26, 2008 | Mitsubishi WS-55809 55" Rear Projection...
No video in any of the TV inputs
first try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Sep 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
DVD's play in black and white
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from dvd player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen when in TV mode, hace HDcable
Blue screen indicates you have no signal/source. Double check that the signal source good. Replace cables if you can, make to look closely at both ends of cable. What is your signal source cable, sat.,?
Feb 23, 2008 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
162 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
