Question about Microwave Ovens
I have a panasonic microwave, model NN-GD566M. The bulb has gone but the microwave still functions ok, I cannot find the instruction manual and need to purchase the part, Can you help. I need the part and also the manual You can call me on 07881 953779, thanks Lorraine
  • Microwave Ovens Master
  • 9,098 Answers
You can find the instructions for this model here and here.
You should be able to find generic replacement bulbs from local appliance parts stores, home improvement stores, or via a local Panasonic-authorized servicer you can locate here.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 27, 2008
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
I need a manual for the panasonic NN-CT562MBPQ
The manual can be downloaded here:
http://www.panasonic.eu/Downloads/en_GB/popup.html
Put in the model number with no spaces: NNCT552W and take the one marked "Operating Instructions".
Feb 26, 2013 | Panasonic Nn-Ct562mbpq Combination...
Panasonic Model #NN7524A Microwave bulb replacement help
microwave---NN-S335 , 800W Plate exploded , Where can I get another ? From C Carver Feb. 23 , 2009 Thanks
Feb 25, 2009 | Panasonic Microwave Ovens
Replacing bulb for microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You should be able to download your owner's manual from Panasonic.net by choosing your region & country, then Support.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jan 03, 2009 | Panasonic NN-2505A Microwave Oven
Model Panasonic Microwave NN-T688SA. Oven light out, how to replace it
You should be able to download your Panasonic owner's manual here.
Dec 06, 2008 | Panasonic NN-T888S Convection/Microwave...
I need to find a replacement bulb for a Panasonic Microwave NN-GD566M
Generic replacement bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you would prefer to order the original bulb, the best place to order Panasonic parts is Tritronics.
You can also call them at 866-779-5835.
Dec 03, 2008 | Microwave Ovens
I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Aug 13, 2008 | Panasonic Microwave Ovens
Panasonic NN-H664 1200 Watts Microwave
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
245 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
