Question about Kenwood VR-2080
Kenwood VR-2080, I plug it in = solid red light, press power button = click blinking light and no display. Can you please help me?
3 Suggested Answers
SOURCE: Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
Posted on May 04, 2009
SOURCE: kenwood VR 208
It works sometimes, mostly the volume bottem
Posted on Sep 30, 2010
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
My kenwood vr-616 keeps cutting off while listining to the radio or watching the dvd, I have plugged the dvd into a different power supply and the dvd keeps playing but the system shuts off and the power...
The unit may be overheating and shutting down to protect itself.
Please check the fan grills and make sure they are not clogged up with dust as can often happen to amps and receivers. If that is the case then a vacuum cleaner can be used to remove the dust.
If the unit is inside a cabinet try running it outside the cabinet. If it runs for longer before shutting down then this would indicate that it is overheating.
I had the same problem with my Sony home theater amp/dvd and cleaning out the dust cured the problem.
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Kenwood VR-616 Receiver
May 02, 2009 | Audio Players & Recorders
Kenwood VR-3090 Red light flashes above power when turned on
You may need to reset the microprocessor, the ownersmanual describes this process as Turn the Receiver OFF,UNPLUG the POWER CORD from the elecrical outlet,PLUG the RECEIVER back into the outlet while PRESSING and HOLDING hte POWER ON button, continue to HOLD the POWER BUTTON for a Second or two, Hope this works for you, if not a CLIPPING problem could be the source only if you set up new speakers or input source. GOOD LUCK
Feb 15, 2009 | Kenwood VR-3090
Kenwood VR-209 Still does not work after the speakers are unplugged.
I have a VR205 with the same problem. I can make it stay on by doing this: as soon as the display lights up turn off the power and then turn it back on quickly. Do this 3 or 4 times. Mine usually stays on after this....the relays latch and all is well I suspect one of the step-start relays as I have checked everything else out and all is in order and the receiver works fine. I would love to find a shop manual for this series of receivers. Anyone know where such an animal exists?
May 21, 2008 | Kenwood VR-209 Receiver
My Kenwood VR-209
your speakers wires are touching together. this system has a protecter so you don't blow out the amp. the blinking is how it lets you know that
Jan 28, 2008 | Kenwood VR-209 Receiver
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
Jan 18, 2008 | Kenwood VR-606 Receiver
Kenwood VR 208
Nov 26, 2007 | Kenwood VR-506 Receiver
Kenwood VR-2080 Logo
74 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
