Question about Dryers
Need switch for Pelonis Fan FS5-40A - Dryers
A remote control for floor fan pelonis
sadly FIXYA does not source spare parts check with Pelonis website.
Apr 03, 2018 | Pelonis Dryers
My utility heater by Pelonis model hb301 serial no. 3011137160 will not heat up anymore .
the over temp safety switch has failed. It is replaceable but is a pain to change as they are usually attached with special high heat crimp terminals. there should have been a a warning light on the front that is supposed to warn you when the high temp switch has been activated.
Feb 15, 2015 | Pelonis Heating & Cooling
Need KSD-301-V thermo switch for a Pelonis HO-O218 oil filled heater
Amazon has lots of these thermostats available from 3 to 5 dollars. This is the most common thermostatic switch failure for the Pelonis heater . Go to Amazon and type in KSD 301 in the search area. The temperature rating of the sensor is approximately 305 degrees
Jan 31, 2015 | Pelonis Heating & Cooling
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis tower heater hc-0116 doesn't stay on for any length of time. Also, the oscillation is not working. What should I do?
these type of appliances are made very fragile the slightest jar could cause this. It is most likely the tip safty switch or thermal protection switch. you can not access either from outside the unit. I wouldn't suggest taking it apart. the part will be hard to get and cost too much. just get rid of it and get a new one.
Jun 07, 2009 | Pelonis FS10S1 Tower Fan
Dryers Logo
76 people viewed this question
Top Dryers Experts
Marvin
Marvin
