Question about King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width Model TG72Y
Rotory tiller shear pin how do you replace it show me a picture ..
My craftsman 5hp tiller hit large rock, tines stopped, loud noise followed and now pull string won't budge. Why?
most tillers are equipped with a shear pin down by the tines. for this reason. if you hit something it will shear the pin and not do damage to your machine. it don't sound like that happened here. make sure the tines are disengaged. if the rope wont pull it may have sheared the flywheel key. there are videos on you tube that will show you how to take off the cover, the flywheel and check to see if this has happened. it may have locked the engine up at the worst scenario.
Mar 30, 2016 | Craftsman Garden
My tiller keeps shearing pins for tines
-Try to use number 8 grade. possibly it hit stone or hard surface
very often that's why it keep shearing the lock pin.
Good Luck
Mai
May 21, 2014 | Craftsman Garden
Husqvarna shear pins break within minutes
if we are speaking about the shear pins on the tines, the ground is the problem and you need to begin your first pass on a more shallow setting and progress to a deeper setting gradually. if we are speaking about the shear pins on the tires w/o engaging the tines then these should not be breaking and I recommend that the tiller be examined by an authorized dealer.
Jun 15, 2012 | Husqvarna Garden
Tiller blades barely turns and you have to hold down forward lever to get them to keep turning
belt worn and too loose, maybe pulley slipping on the shaft, shear bolts or pins broke on tines. worse case sheared key in tranny case for drive gears.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
Tiller keeps shearing off shear pins
chinese steel. use a grade 5 or grade 8 bolt and it won't shear.
Apr 16, 2009 | Garden
Tines don't turn
There is usuall a shear pin on the shaft so that when it hits something serious it will shear off preventing the engine from being ruined. I would look for a shear pin somewhere.
Mar 28, 2009 | Garden
King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width Model TG72Y Logo
150 people viewed this question
Top King Kutter Garden Experts
Jay Finke
Jay Finke
George Merkley
George Merkley
john h
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
