Question about Sony CDX-R30M CD Player
How do I turn on the aux input on my Sony CDXR30M?
How do you can you play music through another device using an aux cord
if sony has AUX INPUT then plug in your comp or I phone through LIne out (small mini plug) then select AUX on your sony system
Jan 05, 2013 | Sony MHC-GX250 CD Shelf System
HOW TO USE AUX
AUX is the auxillary terminal to connect any input to the set. You must connect to the AUX input an IPOD or any device , use the conttrol panel to switch o the AUX and play the source.
Oct 28, 2010 | Sony CDX-F5510 CD Player
Where is the aux input on the sony cdx-mp70?
check the front of the player. If you don't find any Aux input then it means your player does not have Aux input.
Take care.
Aug 23, 2010 | Sony CDX-MP70 CD Player
Whats the aux 4?
AUX MEANS AUXILIARY INPUT, THAT WOULD BE LIKE AN IPOD OR OTHER DEVICE LIKE IT
Apr 29, 2010 | Sony CDX-F7700 CD Player
Where is the aux input located?
aux, just means Auxiliary, or An Extra, it is any other input or output that the unit has in it, that can be used. There is a "Main" input, and any other ones are considered "AUX" or an extra one as well.
Mar 27, 2010 | Sony CDX-CA680X CD Player
Getting the aux. input working
not in less you want to cut the charger apart
Jan 11, 2010 | Sony CDX-CA850X CD Player
I cant figure out how to get an MP3 player to play through my CD player....it has 3 different audio rca jacks in the back...i try all three none worked....is there an AUX setting that need to put my cd...
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
Jul 28, 2009 | Car Audio & Video
All I need to know is how to change a CDX_CA700 CD player to AUX
On the Sony unit (CDX-M100TF) you need to activate the AUX input from the stanby screen. It may work with yours as well...its worth a try!
Turn stereo "off". Press menu and there's an option for the AUX input.
Note: This may not be accesible when the stereo is 'on'.
Jun 29, 2009 | Sony CDX-CA700X CD Player
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Apr 09, 2008 | Car Audio & Video
Sony CDX-R30M CD Player Logo
114 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
