Question about Danby Dehumidifier
The dehumidifier is making a squeaking sound like there is bearing going or needs some grease?
The unit turns on compressor and the fan after awhile the fan turns off and compressor still on.
Sounds like it is a bad fan or bearings. Try shutting off the unit as soon as the fan shuts off and see if the fan turns freely. If not, the fan bearings need lubrication or replacement. If they are not serviceable, you will need to replace the entire fan.
May 19, 2014 | Frigidaire FDF70S Dehumidifier
Dehumidifier squeaks when running
Disconnect it, (DO NOT REPAIR WHILE CONNECTED), remove outer plastic casing (screws), lubricate moving parts with a little WD40 or similar. Re-assemble.
If you can get to the part that's squeaking with a long tube you could try spraying silicone lubricant spray on it without disassembling.
Apr 03, 2014 | Dehumidifiers
Fan squeaking
Try spraying white lithium grease all around the shaded pole motor axle while the motor is running making sure to have it get into the bearings
Oct 15, 2013 | Bionaire Dehumidifiers
I have a Kenmore Dehumidifier the fan will run for a while and then stops. I greased the fan motor it ran for a while and then stopped. My feeling is the fan motor bearing has loosened and as the motor...
does the motor feel extremely hot? how free are the bearings? Is there any squeaking when the fan turns? any resistance at all? If you have a problem with the bearings then change them that would cause the thermal overload to trip in the motor to unsure it doesn't burn out.
Aug 14, 2011 | Kenmore 54351 Dehumidifier
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
Dehumidifier makes a lould clanking sound when the fan spins. I took of the back cover, the fan is not hitting anything, sounds like it is coming from inside the motor.
Sounds like a bearing went bad. Unplug the unit and grab the fan blades and move them. If they slop around inside the motor, you have bad bearings.
Sep 28, 2010 | Fedders R6DH45X Dehumidifier
My dehumidifier makes squeaking noises when running. How do I stop this?
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 02, 2010 | Whirlpool AD40USL Dehumidifier
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Fan motor making squeaking noise; sounds like bushing failure.
PLEAS IF SOUND REALY FROM THE MOTOR SOME OF THE MOTORS HAVE BEARING CAN BE REPLACED BUT IF IS BUSHING BETTER TO CHANGE THE MOTOR.
Sep 17, 2009 | Maytag M7DH45B2A Dehumidifier
Danby  Dehumidifier Logo
179 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
