Question about Garmin GPSMAP 176C GPS Receiver
Hi the screen on my 176c is so dark it can barely be read. I have to turn the light on to see whats going on.Is there any way to restore it to its former glory cheers ......john wainwright. australia
    Brigadier General:
  • 4,090 Answers
John, the light sensitive IC has failed. This is a small piece of electronic wizardry that adjusts the brightnessdepending on the ambient light. At night is is supposed to add brightnes and in sunlight reduce it
The sign of failure may have been early but you didint notice it. They often turn on ok then suddenly in daylight the screen will darken, turning the unit off and on resets it for a while. however it gets worse as time goes on.. iT is not a DIY and has to be sent back to the manufacturer for correction.
Contact Garmin for a quote before submitting it for repair, you might need a chair to sit on when they give you an answer. Contact the service support in 7 hills NSW 1 800 235 822
Please rate my help++++ Thanks forf using FIXYA
Posted on Aug 04, 2010
Dark screen
It's either the logic board or some component that has gone bad. No real way to repair it, unless you tear it down and it's maybe a bad joint or something simple like that.
Best I can tell you to do is to FULLY discharge the battery, as in turn it on, let it die and keep pushing the power button to make sure it's dead. Takes about 48 hours. Once you do that, plug it in and DO NOT try to turn it on, just let it do it's thing and see what happens. Maybe hooking it to a computer after that and seeing if an update will help, also make sure that if there are any cables, external antennas, or cards plugged into it, to remove them during all of that. Best of luck for a resolution.
Nov 02, 2017 | Garmin GPSMAP 176C GPS Receiver
Cant read the menu. Is backlight broken.? I can see the word garnin when I turn power on. But the menu is difficult to read- Is it konfigutation for dark or light screen?
It depends on the model - but CCFL tubes are used by Garmin to light the screen of GPS devices. A CCFL tube comes with a high voltage inverter to power the tube. Meaning either the CCFL Tube or the Inverter can be dead.
Symptom is a barely readable screen and becomes a bit more visible when looked at from an angle. No light comes from the screen at all.
The inverter can be tested by holding oscilloscope leads close to the screen. A sinus waveform of about 50 - 60 Khz should be visible when the device is powered at full screen intensity.
Jul 10, 2011 | GPS
Hi, i have a Advent 3001 roma laptop, unfortunatly i dropped it this morning and the battery fell out, after replacing the battery and turning it back on the screen is very dark, i can only barely see the...
sounds like the light bulb inside the LCD screen broke its hair thin and very fragile will have to replace screen could be more expansive than a new laptop.
Mar 01, 2011 | Advent Computers & Internet
My son's TI-83 calculator screen is very dark. The calculator appears to be working but I can barely read the screen. Any suggestions?
Try adjusting the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the down-arrow key to darken the text. If you go too far, use the 2ND and up-arrow keys to lighten the text.
Feb 09, 2011 | Texas Instruments TI-83 Plus Calculator
Dark screen after being dropped in water
try drying it with a throughout hairdryer ie take the battery out and give it a blast for maybe5 minutes then try again.
Mar 09, 2010 | Nokia 6500 Slide Cellular Phone
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
Jul 22, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Can't see a thing on screen
hi sir
please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
if doesn.t work mite memory card may be corrupted..
Sep 01, 2008 | Nokia N95 Cellular Phone
Screen to dark to read
Find out if you are still in warranty this is not fixable.
Mar 01, 2008 | RCA OPAL M4001 MP3 Player
Sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
My 176c is not responding
get the download (updater from garmin website , download it then hook up 176c to computer and run file .if it doesnt go thru hit power and try again if you get the screen under a good light so you can see it will say downloading when this is done your screen will be back to normal .I dont remember if the unit is on when it beeps or off .try both ways if it doesnt work replace batteries as even though your not seeing the screen the unit is still on like i said ; fresh batts and try it and if it doesnt work hold down power key for a second or two and try again. good luck PS garmin doesnt know this i figured it out myself ...bob
Feb 24, 2008 | Garmin GPSMAP 176C GPS Receiver
Garmin GPSMAP 176C GPS Receiver Logo
603 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
