Question about Toshiba MV13L2 13 in. TV/VCR Combo
My toshiba MV13L2 TV/VCR the remote does not work,I replace the remote but it does not work all the time.
  • msfelo Aug 05, 2010
    the remote for my Toshiba TV/VCR combination model MV13L2 does not work.I replaced it withwith a factory rebuilt remoter.It worked for a while and now it works ocasionaly. Some times one or two buttons. Most of the time not at all.
    Thank I will give it a try.
  • Toshiba Master
  • 3,866 Answers
This sounds like a intermittant issue with the front IR reciever inside the tv. A replacment of that will cost $90 bucks respectivly. I would try to clean then inside lens and see if that approves anything if not replacment of that ir control board as a whole.
I hope this sheds some light on the problem and I hope my answer does help you to the fact that it needs to be repaired.
1. Try cleaning the ir lens first inside and out
2. total replacment of the front IR controller inside the tv (for the fix)
Thanks for your question, Please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 05, 2010
  • Toshiba Master
  • 11,800 Answers
In that case the connections to the remote sensor on the case of the tv are loose. Open the tv and reseat them. If necessary you must resolder them.
  • Azrael SRL Aug 05, 2010
    In that case the remote itself (or the rubber pad with the buttons to be more precise) is defective. You must replace it, it can't be fixed. Here you can find one
    http://ceaccessories.toshiba.com/detail/...
How to connect old analog tv to blu ray dvd player
You will need to connect to the component inputs on the TV, red, white and yellow sockets. If the DVD does not have these outputs you can get a converter cable such as this
http://www.ebay.com/itm/HDMI-To-3-RCA-Cable-High-Quality-Male-Adapter-Converter-Cable-For-HDTV-1-5m-/190856204300?pt=US_Video_Cables_Adapters&hash=item2c6fea900c
Dec 27, 2013 | Toshiba MV13L2 13 in. TV/VCR Combo
I am hooked into cable and not on antenna. I can get sound w/ the DVD player that is hooked up to the tv but no sound on the tv. The tv channels come in clear but no sound.
May be a simple problem with the SAP (second audio program ) being set to the wrong place, run thru the onscreen audio menu and see if this is the case
Dec 18, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Vcr will not record sound any more.
Try with another cable, the cable may either be loose or damaged. If that doesn't work it is a problem with the VCR itsself
Aug 13, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
No factory remote i can't acess to the menu system
Most televisions and monitors have a menu button next to the power, volume, and channel buttons on the face, top, or side of the set. It can be a pain but you can usually press the menu button to bring the menu up and then select and change settings by pressing menu again to choose a setting and using the channel and/or volume up and down buttons to raise or lower the setting. The exact function varies based on the set so you may need to fiddle around a bit. Unfortunately some sets do require the remote to perform some functions.
Jul 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
it should tell you on the board where you took it out of it usually around 125v/4amp
Feb 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
No picture, no aundio
most tv/vcr combo has only one power supply source which is located in the vcr unit. u have a power supply circuit problem. try to check the rectifier, filter capacitor and the regulator ic/transistor. good luck!
Feb 02, 2007 | Toshiba MV13L2 13 in. TV/VCR Combo
Toshiba MV13L2 13 in. TV/VCR Combo Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
