Question about Maytag MMV1153B Microwave Oven
Maytag Model MMV1153BA; only 3 years old. After a power outage, unit would not heat up; then entire unit shut down. Displays returned about 2 hours later. However, it still does not heat. Are we buying a new one?
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
  • 949 Answers
SOURCE: new maytag power shuts off and comes back in half hour
Depending on the model you may need a 15 or even up to a 20 amp circuit to operate the microwave. Check the installation instructions to be sure. What is most likely happening is the circuit in your home is not powerful enough to run the load of the microwave oven. If this is the case it could be dangerous. I would strongly recommend you have an expert examine the house wiring prior to starting the unit again.
Posted on Apr 20, 2010
cpldw48
  • 211 Answers
SOURCE: My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Posted on Apr 25, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: We have a model # mmv1153bas over the range
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
It is vital that the cooling fan runs, or the magnetron will be destroyed. Repeated shutdowns like this are endangering the magnetron, assuming it's not bad already.
Your owner's manual will cover checking the filters and will cover warranty terms. The magnetron may still be covered.
If for some reason you don't have your manual, you can download it here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 28, 2010
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
My glass turntable broke for my Maytag Microwave Oven. Model #MMV1153BA, where can I find a replacement?
try microwave repair shops as they may have plates from units that were repairable or may have new plates in stock
contact maytag direct and see if they are available and where from
Oct 31, 2015 | Maytag Microwave Ovens
Where r fuses at on mmv1153ba
If power turns on or interior light goes on, it is not the fuse.
Nov 17, 2014 | Maytag MMV1153A Microwave Oven
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
MMV1153BA brand new, less than 2 weeks
The magnatron may need replaced..(this is what makes it cook)
Dec 10, 2008 | Maytag MMV1153A Microwave Oven
Microwave not working
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Nov 25, 2008 | Microwave Ovens
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV1153B Microwave Oven Logo
110 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
