Question about Kenmore 47702 / 47704 / 47709 Electric Single Oven
Oven does not ignite broiler does ignite burners do ignite
  • 50 Answers
The ignitor should pull 2.8 amps or more. it can lite but not release gas. just beacuse it is glowing doesnt mean its good. check amp draw w/ meter if less than 2.8 amps. change it out. if doesnt glow or draw any amps. check to be sure have 120v. then change ignitor.
Posted on Aug 04, 2010
The oven on my g70m no gas coming through the grill still operates
Good morning Mark, you most likely have a weak oven igniter. That would prevent the gas valve from opening causing a no heat condition in the oven. Also try the broiler if it's separate from the bake burner.at the top of the oven cavity as opposed to the broiler drawer underneath. That igniter typically gets used less often and takes longer to wear out and the broiler will come on. It could also be a bad gas safety valve but that is an unusual problem. Hope that helps.
Feb 10, 2018 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Oven won't light. Broiler will ignite and
I don't know how new or what brand your oven is, but chances are you have a bad igniter the bottom burner. It is a small element attached to the burner that should glow red hot when you turn your oven on to ignite the gas. This is the most commment setup and problem. You will have to remove the bottom tray (there are usully 2 finger screws holding it in) to see it. It should look something like this:
http://www.theignitorstore.com/product/306602/range_oven_igniters
If you turn the oven on and nothing happens, turn it back off. You can disconnect the igniter, connect a multimeter set to volts AC, turn back on and check for voltage (120 AC) Don't let any bare wire ends touch the oven or you. If you have power there, its the igniter.
Just get the model number off your oven to look up the proper replacement. Replaces with 2 screws. Make sure it mounts close to the burner. It should only take a couple seconds after you hear the gas turn on to ignite. Hope this helps.
Jan 02, 2010 | Ovens
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
Kenmore 47702 / 47704 / 47709 Electric Single Oven Logo
87 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
