Question about Delta & Single Handle Shower Faucet
My shower goes from warm to scalding and then to cold without any adjustment to the controls...is this a hard water problem? is this a common problem? my faucets were installed 1 year ago.
  • 43,501 Answers
No it more then likely is because of fluctuating pressures...this could be because of other water usage in the house or even in the water entering the house...to see hwat it is the water pressure would need to be monitored at different locations to find the source of the problem...likely if it happens when somewhen else in the house flushes a toilet then you know where it is...
heatman101
Posted on Aug 05, 2010
I'm runnin out of hot water in minutes.Baseboard is fine.The hot water pipe off the boiler is hot and it goes thru a dial or adjuster to the taps.And it's warm/cold after that dial. Where do I start?
that adjuster is there to reduce the water temperature so that scalding from boiling water doesn't occur
they can be adjust but if this problem has come in after a period of time then the sensor wax inside the adjuster is not as it should be.
they do fail and need replacing
most plumbers put the unit on the hot water outlet because they are lazy as the standard says that it is primarily for use on the shower, bath, basin systems and wash machines and kitchen sink are not required to be temp controlled.
Apr 20, 2015 | Water Water Heaters
Our gravity fed shower only goes warm when bath cold water is turned on
If you are using a conventional shower valve of recent manufacture, there is a safety feature to prevent scalding accidents when it is connected to conventional plumbing on a pressurized system. If there is no cold water pressure against the valve, it shuts off the hot water completely. It is called a pressure balancing valve by most manufacturers.
In other words- it is supposed to do that.
There are ways to bypass the valve, but you may want to keep that feature if your storage temp is capable of temps above 110 degrees F or 49 degrees C.
Dec 14, 2011 | Home
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Aug 03, 2010 | Delta T13420 Chrome Classic Single Handle...
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
Hot water pipe hot going into mira shower but no hot water coming out
need to adjust the anti-scald [protection] new systems are shipped in cold position and u adjust it to ur comfort
Feb 15, 2010 | Water Pik Hand Held Shower
Water temperature fluctuates between scalding and freezing
The mixer valve has a torn seal. You'll need to remove the spool.
With the sppol in-hand... and hardware store can hook you up with a replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 02, 2009 | Washing Machines
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Delta & Single Handle Shower Faucet  Logo
101 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
