Question about Garden
What is the flying sourcer shaped part on a briggs and stratton Honda petter lister
SOURCE: I'm not sure if the nut comes off turning clock
The flywheel nut should come off counterclockwise. Hold the flywheel with a good pry bar against some solid so as not to damage anything. After that is off the flywheel will be on there real tight. Let me know if you haven't done it before , I can help you there also.
Posted on Mar 28, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
backwoodsctr
  • 169 Answers
SOURCE: i have a briggs stratton 28v707 and am trying to
Briggs ang stratton offers a very inexpensive flywheel puller for under 20 dollars. The part number is 19203 and is avail at all briggs & stratton service centers. If you dont wish to buy the puller the dealer can pull it for you for a minimal fee. Alternate method which i do not recomend is to strike the flywheel with a brass hammer. Somtimes it will pop right off. Good luck hope this works
Posted on Nov 23, 2009
Lpw 46 lister petter generater. runs at 1500rpm but under load drops to 1350rpm
Sounds like its overloaded, really need to know how many KW's kilowatts is the gen set, and also what you are powering, but sounds like a short in wire or just plain overloaded.
Mar 07, 2016 | Electrical Supplies
It starts and runs but gets hot and quits
the only way for an air cooled motor to get hot is from the cooling fins on the head and cylinder to be blocked from straw and mud
remove the cowl on the motor over the fly wheel and clean it all out
Nov 07, 2015 | Briggs & Stratton Garden
How do I time model 128802?
Hallo, I'm looking for a repair manual for 128802-1724-B1 Briggs and Stratton engine. I'm struggling with a the governor setup/ adjustment.
Any help is appriciated,
Frank
Jul 21, 2014 | Briggs & Stratton Garden
How to set timing on 23 hp briggs and stratton intek v twin 23 hp
The only way to set the timing is by aligning the cam and crankshaft gears, before doing this check the shear pin in the fly wheel to see if it has been sheared off.
Oct 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do i get the flywheel off to get to the points i have no spark
use a three prong pulley puller and pull it off before this are you sure you have points chek blad brake is disengaging befor pull fly wheel
May 13, 2012 | Briggs & Stratton Briggs Stratton...
Torque settingsfor head on lister petter mini6 engine
I have just rebuilt one for our Westerly 21. This is from my Petter 'A' range workshop manual:-
The water cooled engines (AC1W etc.) are:cylinder head nuts: 30NM (22 lbft) except 32.5NM (24 lbft) for the one that also holds the rocker.
Valve clearances are 0.1mm (0.004") COLDReset valve clearance after one hours running since torquing the head.
Retorque head and set valve clearance after initial 20 hours running
I believe Mini-6 refers to the water cooled engines but just in case, the air cooled engines are 27N (20 lbft)
Mar 27, 2012 | Cars & Trucks
I have a briggs stratton 28v707 and am trying to remove the fly wheel to get the alternator off to replace and am having some issiues getting the fly wheel off any sujestions or advice.
Nov 23, 2009 | Briggs & Stratton Garden
My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
May 31, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
