Question about Maax Home
Ihave a shower with sliding Maxx doors. The bottowm of theframing (iguess its the drain tray has come use from the shower unit. Where can I get instructions how to reinstaal? What is the best way to attach the bottom framing to the shower base? If I use adhesive what type. What is best way to assure theconnection is waterproof.
I pushed mine back on using the rubber insert to hold it in place. Th bottom came lose, I opened the door and it flew open and shattered in millions of small pieces. A blood mess! This could be very dangerous, I was only cut up a bit. Am looking for a replacement. Be Carfull!
Posted on Oct 04, 2010
How do I adjust the position of the sliding doors on my quadrant corner unit shower or how do I remove the doors to clean behind? thanks
Look at the top and bottom mounting points for indications that it may be adjustable. It may be necessary to remove the door to expose the adjustment provision.
Aug 22, 2015 | Home
I need to replace door sweep for sa12025-01 maax
need to replace door sweep on maxx shower
Oct 22, 2013 | Plumbing
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Dec 14, 2010 | Maax Acrylic Base for Shower - 102623
The freezer side of my admiral leaks (collects water and it freezes) at the bottowm. then leaks to the floor. what can I do to fix it?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Oct 29, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ihave a paper jam help
Pull the paper tray out and look in there. open front door and pull out the toner/drum unit and look in there. open the back door and look in there. and thats all I can say about that. Steven 818-888-0006
Mar 05, 2010 | Brother HL 2140 Laser Printer
Water leeking from hose ,and water not going down thr drain of shower unit
what hose? as far as the drain goes, it needs to have the hair cleaned out of it. Do you mean hand held shower hose? needs tightening or replacement
Jan 10, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Cubicule shower -lost the sliding door wheels on one door.
You can get these at ace hardware or most hardware shops will carry them just take a sample to match it with yours.
Sep 18, 2009 | Home
Home Logo
182 people viewed this question
Top Maax Home Experts
Mike
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
