Question about LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher
I have an LGF6920ST dishwasher, puchased 18mos ago. since i've had it, it's gone from marginally ok to bad, now leaking puddles onto my floor from the lower left side (as i face it) of the door. besides occasional poor drainage, smelly water in the bottom to horrid cleaning (yes, it's attached to the hot water, i use rinse agent, etc) i rinse my dishes, in fact scrub them before putting them into this dishwasher, and honestly they come out nastier than when i put them in...primary concern right now is that i need to fix this leak. i have removed the front door panel, after unplugging and checking all hoses...now i'm stuck...looking for some kind of schematic for this thing before i haul it to the curb.
  • 423 Answers
SOURCE: LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Posted on Mar 29, 2009
omaharox
  • 166 Answers
SOURCE: door leak on built in LG dishwasher.
Check and make sure the unit is level front to back and side to side.
Check all 3 spray arms for plugged or restricted holes that may be diverting water in the wrong direction..
Posted on Jan 09, 2010
SOURCE: Water dripping out of door vent in lower left side
This is being caused by the vent tube design. The lower fitting is pushed up into the upper fitting so water leaks out from the top. The fittings are designed backwards. Remove front door panel and their will be a white tube running down the side. That tube is pushed up into its mate. Pull it down and silacone calk all around the out side of that pieces and the inside of the upper piece. put them back together and then tape it with some duck tape. DO NOT US FOR AT LEAST 24 hrs.
Posted on Aug 21, 2009
SOURCE: Lg DISHWASHER INTERMITTENT WATER LEAK
I had the same problem - intermittent leak at door, left side. The solution is to replace the level sensor and/or the inlet valve. This intermittent electrical malfunction allows to much water to enter the diswasher and spill out. I changed these parts once, it solved the problem and 8 months later the problem has returned.
Posted on May 01, 2010
  • 4354 Answers
SOURCE: Leaking water through the door bottom left about 6
The bottom of the door is NOT ACTUALLY SEALED. if you use the wrong or too much soap this can happen. Unit level is important.
Posted on Sep 26, 2010
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
PUDDLE OF WATER ON FLOOR MAINLY AFTER WASH IS
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
May 15, 2010 | Dishwashers
I have a Frigidaire dishwasher that I have had for a year and a half - 8 months ago it broke and leaked into my kitchen ruining my wood floor which had to be replaced. Shortly after that the top sprayer...
I would check to make sure that the top spray arm wasn't over tightened when it was installed. That spray arm threads onto a plastic supply tube which is easy to strip, which will cause it not to tighten properly and leak down the side of the dishwasher and acros the floor.
Mar 24, 2010 | Dishwashers
Kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Feb 17, 2010 | Dishwashers
HDB24EA is leaking from the bottom
If a dishwasher is leaking onto the floor you either have a loose connection--supply or drain, or the pump seal is bad. The connection leaks are easy to fix-just tighten. If you ahve a bad pump seal you're going to have to spend money. Usually about $60 for a seal kit if you do it yourself or a LOT of money if you have repairman do it. If this is an older machine and the seal is gone you might want to toss it.
Sep 18, 2009 | Haier HDB24EA Built-in Dishwasher
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridgidaire Gallery Series Dishwasher Leaks from bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wre
Mar 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher Logo
242 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
