Question about Olympus Stylus 820 Digital Camera
The blue power light is flashing on and off but i can not switch it on or use it on the PC. It was working fine plugged into the PC and then had a power cut so everything cut off. Since then the little blue light on the power button keeps flashing every few seconds but no matter what i do I can not switch it on.
    Novelist:
  • 178 Answers
This camera is very good and takes excellent pictures.
Check out repair at Teleplan Camera Repair.
They have an immediate online quote that will give you the cost too.
Posted on Aug 04, 2010
Completely dead acer chromebook..working fine on battery when plugged in died
So did you unplug the power supply and try to restart it? When you plugged the power supply in did the power light come on on the power supply showing it was working? Blue light usually.
Sep 23, 2016 | Acer Computers & Internet
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
Computer won't turn on. Blue flashing light.
The blue light blinking indicated that your processor if faulty.So please check your processor. Take it to tech department for new processor.
I hope this solution has been helpful.
Sep 25, 2010 | Medion MD-1704 PC Desktop
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Asus z71v wont turn on
Tricky one this without looking at it - You may very well have a faulty lead, transformer/voltage regulator,power/plug or switch. Would need to do hardware tests to determine the fault. Regards, Freddie
Sep 07, 2007 | ASUS Z71V Notebook
Olympus Stylus 820 Digital Camera Logo
103 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
