Question about Samsung WF203ANW Front Load Washer
We just bought a front loading machine and it seems to have hardly any water while washing. How much water should there be? Right now it looks like only the clothes are wet but no other water sitting in tub. I just didn't know if this is normal?
  • 343 Answers
Front load washing machins are very water conservative. In fact a lot of moldern F/L washers use so little water that it doesn't even come up to the bottom of the door.
If the machine completes it's cycle, it obviously 'thinks' it's getting enough water to continue..
IMPORTANT...Do not overuse detergent!! This can seriously shorten the life of a F/L...! You're treating the amount of water...NOT the amount of clothes...Happy Washing
Good luck....Nomess
Posted on Aug 07, 2010
What is Wrong with my whirlpool front load washing machine,Mod.#GHW9150PW1?
f06 relates to a motor fault....easiest fix is to replace the motor......
cheaper on ebay........cheers
Oct 13, 2016 | Whirlpool Duet GHW9150P Front Load Washer
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Wash cycle water level
the water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Aug 13, 2008 | Washing Machines
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
KENMORE ELITE HE 3- MODEL 44832200
is the washer full of water and is the sound like a fast clicking
Dec 31, 2007 | Kenmore 44832 Front Load Washer
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
Samsung WF203ANW Front Load Washer Logo
142 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
