Enter the last four digits of your phone number on your cell phone PIN screen. When setting up a cell phone PIN, the default number assigned is the last four digits of your cell phone number for most cell phones.
Enter 9999, and if that doesn't work try 1111. The number sequence 9999 and 1111 are other standard numbers assigned when choosing a cell phone PIN.
Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number under the battery. Reinsert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen. The last four digits on your IMEI number can occasionally be the service provider's preset PIN for the cell phone.
Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code.
Go to one of the links in the Resources section and have your IMEI number ready. These websites will ask for your phone model and IMEI number and then charge you a set fee for the unlocking PIN.
Hello
<br />
Personal identification number (PIN), is a secret number that is used to unlock the phone, unlock in the sence of accessing the device you are using. It is made up og 4 digits that is giving to you when you buy a phone number. It comes with your phone number not with the device, so that means you can still use the same pin on different mobiles. But always remeber your pin number because if you lose it then your phone will be probably blocked!
<br />
Following are the some ways to find the pin code:
<br />
<br />
<br />
<br />
Call your service provider and request the PIN. You will have to prove you are a customer by stating your cell phone number, address and NIC number.
<br />
Hope this helps, if so do rate the Tip.......
Hello
Hope this helps.
If it is the factory set pin, most likely it will be 0000. Could also be 1234 if you have tried the first. Tesco really needs to take the responsibility here and get your phone unlocked for you. Its not something the average person can do. I would ask for the manager and tell him what is going on. If that doesn't work call the corporate office. They can give you the #.
Complete information : The SIM card protects
your subscription and not the phone from unauthorised users. If you
change SIM cards you can still use your phone with a new SIM card. Most
SIM cards are blocked at the time of purchase. If your SIM card lock is
on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK
is supplied by your service provider. You can edit your PIN and select
a new four to eight digit number
If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
When PIN Blocked appears enter your PUK > OK
Enter a new four to eight PIN > OK
Re-enter the new PIN to confirm > OK
To edit your PIN:
> Settings > the General tab > Security > Locks > SIM Protection > Change PIN
Enter your PIN > OK
Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
> Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
