When i try to hook up the wii to wireless connection it will test the connection then it says error code 51330 and then says to change the internet settings
  • 15,935 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Thanks!!
Posted on Aug 04, 2010
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Jul 24, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
I tri to connect internet error code 51330
Error code 51330 is trying to tell you that the Wii Wireless Adapter cannot connect to your wireless router. The most likely reason for this error is that the password you entered is not typed correctly, or that you forgot to type one in at all. Remember that security keys are always case sensitive.
Jul 01, 2011 | Nintendo Wii Console
I can't get my wii to connect to my wireless connection. I went to Internet settings and did Put the wireless connection name, did the connection test and it said unable to connect to Internet. The error...
go to settings wii settings then click internet and click any connection search for access point then type in pass(optional) and then click ok go back to wii menu and connect
May 02, 2011 | Nintendo Wii Console
52030 error message when trying to hook to the internet
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jan 23, 2011 | Nintendo Wii Console
Error code 51330
Apr 25, 2010 | Nintendo Wii Console
Error code 51330
That's usually a problem related to wireless security. You'll want to try to make sure your computers can connect to the wireless--or see if it's working or not.
If everything is good. Make sure the password you have on your Wii to connect your console to the wifi is good.
That should work... if not, reset your wifi settings and try again!
Feb 08, 2010 | Nintendo Wii Console
Wii code:51330
boussole,
There are a few things you can try to fix this error code (51330):
  1. Set your router to Mixed Mode. It won't work on G-only mode.
  2. Set the channel on your router to either 1 or 11.
Let me know if this helps. Good luck!
Feb 09, 2008 | Dell Wireless 2350 Router
Computers & Internet Logo
Alun Cox
David Payne
David Payne
