Question about Maytag Dishwashers
Maytag dishwasher Model # DWC4910AAW SN A9830611KY Doesn't clean dishes anymore...leaves white soap (Cascade) residue on all; doesn't clean dishes anymore.
  • 37 Answers
Msbcox -- Check for residue in the strainer under the lower washbar. Remove the lower dish rack. Strainer is under washbar. Sounds like it is not draining properly. Write back if you need more help. -- SWT
Posted on Aug 04, 2010
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
I have a Maytag dishwasher model #MDB7160AWW. I am finding a cloudy residue on my glasses and cups on the top rack. Our water is hard. When the washing cycle is completed, there is still soap residue...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 14, 2011 | Dishwashers
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
Residue on dishes Dish washer is maytag Dwy 7402 aab purchase in 1996 Soap residue, cleaned top spray arm, but cannot get the bottom off, is there a trick to it without breaking the plastic
heatman101
Sep 18, 2010 | Maytag MDB5100A Dishwasher
#1 Dishes and glasses are not clean. Glasses come out with *** film. #2 Cascade gel soap residue in cup dispenser and on dishes close to it. #3 Not drying glassware in upper rack. #4 Black ***...
heatman101
Jul 14, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Our Maytag Quiet Series 400 has stopped getting the dishes clean..It leaves residue and food on the dishes.My husband has taken it apart and there is nothing that he can find that might cause this.We have...
heatman101
May 03, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
360 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
