Question about Dell W3000 30 in. HD-Ready LCD Television
Someone gave me a dell w3000 tv and i hooked up the speakers and cable line and plugged in. the tv button turns on and green light comes on but no picture or sound
  • 3 Answers
I have this tv, and have had the EXACT problem. my solution was simple. just need patience if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus.
Posted on Aug 14, 2010
  • jspeeddemonf Jul 12, 2011
    After reading your post I took a trip to Radio Shack to purchase the resistors. The closest size they had were 220uf at 35v so I went ahead and put those in acccording to your instruction. the monitor turns on with picture and sound like a new unit. thank you for the helpful post!
Dell w3000 no green power light unit will not power on
This was a product malfunction with that TV. Dell ended up paying out $$ in a class action suit over this product...I think I got a check for like $30 in the end. There is no fix I was told...but try to toggle the master switch, or unplug and plug in again - that often times worked for me. In the end I bought a new tv though because the frustration level was too much.
Mar 30, 2013 | Dell W3000 30 in. HD-Ready LCD Television
W3000, power and audio but not picture
Yes I tried it and now I have nothing, not even a green light. So much for that. I have 2 of these sets. If you never unplug them from 110 I never have a problem. Un plug them and wait 2-3 days and nothing.
Any lawyers what to take this on?
Jul 08, 2009 | Dell W3000 30 in. HD-Ready LCD Television
DELL TV Speakers
hook another set of ext speakers to it. if no sound, its your audio bd not the speakers. hook ur dell speakers up to something else as well for verification.
Oct 22, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Weak sound from Dell W3000
Its possible that the speakers that came with the TV aren't amplified. Do you have another set of speakers that are to test the audio output?
Jul 26, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Power want come on tv
Yes, I believe it is a power supply issue.... Problem is, I can't locate one
Oct 28, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 has green power on no video just audio only
Had same problem as described by others, green light, audio, but no picture. Decided to look inside. Layed the TV face down on three textbooks (1 at top & 1 at left & Right) so that back (9 large screws & 2 small screws) could be removed along with stand. From the power supply (board that 110v AC plugs into) there is a cable connected to a circuit board on the left (again looking from the back of the TV) covered by metal shielding. Unplug this cable clean the male contacts with a miniture wire brush (bought mine at Home Depot) & plug the cable back into the socket. With rubber gloves (just to be safe) plug the AC cord into the back of the TV & wall and turn on your TV. The bulbs should activate in 7 - 8 seconds. Reassemble the back of the TV & install the stand. Enjoy your TV Doug
Sep 08, 2007 | Dell W3000 30 in. HD-Ready LCD Television
W3000
It's repairable, sounds like the main board, but try some other cables and sources to see if the same thing happens
Oct 29, 2006 | Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 30 in. HD-Ready LCD Television Logo
1,018 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
