Our Maytag LAT3500 will fill with water but when it should start to agitate it makes a humming noise and doesn't begin to agitate unless we mess with the timer. My husband took the timer off and took it to a repair store and they told him they didn't think it was the timer since we can get it started by turning it around. What else could the problem be?
    Problem Solver:
  • 6 Answers
Need to check all the wires that connect to the timer, and check if they getting the voltage that they need.
Posted on Apr 26, 2008
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
My Maytag washing machine will fill with water but will not agitate as soon as the water level gets up the water shuts off and when it shut start all that happens is that it makes a humming noise
First check to see if the belts are all on under the machine, and see if the motor is turning. Chances are you have a broken belt, or the belt may be stretched and worn.If the belt is on and the motor is not turning, you may have a burnt out motor.If the belt is on and the motor is turning but the agitator isn't, you probably have a seized gearbox.But check the belts first.
Jun 30, 2011 | Maytag Centennial MTW5800TW Top Load...
My washer fills with water, then when its about time to start agitating, it just makes a humming noise, and doesnt agitate
You may just simply need a new belt. If not there could be 2 other issues, like something being stuck in the drain pump, or possibly a bad motor. Does it have any strange smell coming from underneath?
Dec 01, 2010 | Maytag PAV2300 Top Load Washer
WILL NOT AGITATE, SPIN OR DRAIN. WASHER FILLS WITH WATER, HOWEVER, WHEN AGITATOR CYCLE BEGINS, MOTOR HUMS AND BELT WILL NOT MOVE.
Open the back cover and start the washing cycle. When the agitator cycle begins check if the motor rotates. If it does not and the humming sound comes there is problem is withe motor. Also check the tightness of the belt. Even if it is loose it does move but it is slippery movement unless it is completely loose. Anyway the problem is with your motor and the connecting bearing/pulley. You have to ask a technicians to help you out
Sep 29, 2010 | Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Jan 01, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
My Maytag Performa washing machine filled up with water, and now just makes a humming and clicking noise. It will not agitate, spin, or drain.
sounds like your drive belt is lose.
Open the machine and check it
here is the link for your PARTS
includes also drawing
Jun 19, 2008 | Maytag Washing Machines
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
