Question about Honeywell Heating & Cooling
Trying to clean a Honeywell HT-380BP High Performance Turbo Force Floor Air Circulator Fan and can not figure out how to remove the grille assembly?
4 Suggested Answers
jbjaxiis
  • 95 Answers
SOURCE: I have a Honeywell triple
should be clipped in place, gently pry at the seams
Posted on Aug 10, 2008
Benimur
  • 6966 Answers
SOURCE: I need an owners manual
For a Honeywell HF-810 Mega Turbo High Velocity Floor Fan, pls click here.
You need Adobe Acrobat Reader to view/print these documents, to download click here.
Hope this be of initial help/idea. Pls post back how things turned up
or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
Terry Corrow
  • 10875 Answers
SOURCE: Honeywell Turbo Force Whole Room Air Circulator HT-908 Wiring diagram
contact honeywell
Posted on Jun 18, 2015
How do I clean the table fan? It is very dirty.
Remove the front grille with a phillips screwdriver, there are also two T10 Torx screws on the top and bottom. Wipe everything down with disinfectant wipes. Do NOT use water, with the exception of the front (dry it thoroughly). Don't remove the fan blades. Replace the front grille and screws.
Jun 25, 2015 | Honeywell HT-800 Table Fan
How do you clean the table fan?
You can use a brush with assistance from high pressure compressed air- from a Air compressor or if you reverse the vaccum cleaner ports available in some models.
While the air is blown brush to clean the grill and blades. Use a face mask so as not to inhale the fine dust. Finally clean using a degreaser spray like WD40.
Jul 01, 2011 | Honeywell HT-800 Table Fan
How many watt it have?
    Features and Benefits:
  • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
  • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
  • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
  • Versatile design makes this fan great for use on desk and table tops
  • Wall mounts with separate purchase of hardware
  • Equipped with a carrying handle for transport
  • Dimensions and Weight:
  • Size: 6.33" x 11.375" x 11.125"
  • Weight: 3.5 lbs.
    Power 50W @ 110V
    Power 60W @ 220V
Feb 14, 2011 | Honeywell HT-800 Table Fan
I purchased a Honeywell HT-380BP Turbo fan disassembled and in a box at a thrift store. Is there anything by way of a circuit diagram I can reference to put it back together? There's a motor with seven...
I Guess nobody has the Answer....
Red= high
Yellow= med
Brown= low
White=com
Gray= neautral
Black 2X= live? ACL on the board.
the cap is connected to white & gray.... I want to bypass the electronic board w/ a manual 3speed switch cause I think the motor is still good!!
nobody has the answer?
Aug 27, 2010 | Honeywell Dryers
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
I need an owners manual for my Honeywell HF810 Mega Turbo high velocity Floor fan.
Sep 09, 2008 | Honeywell Heating & Cooling
Removable grilles for easy cleaning?
We just figured this out ourselves. There are four (4) screws on the back of each fan that when undone it releases the grill for cleaning. But the fun part is getting the screws back in to the little holes. But all in all we got it clean...
Jul 20, 2008 | Honeywell Dual-Action Air Circulator Fan -...
Remove grille on fan fan to clean claimsto be easy not to me
I have taken mine outside before and used a leaf blower. Blows all of the dust out and works great on the areas that cant be reached
Apr 06, 2008 | Honeywell HT-800 Table Fan
Heating & Cooling Logo
75 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
