Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a sony trinitron 36 in
I have one of those big and heavy 36 in sony trinitrons. I think there was a power outage while I was gone. Now the picture looks like everything has lines coming off of it, kind of smeared I guess. My JVC 19 in that was in the other room doesn't work now either, I'm not worried about it since the 19in is so cheap though.
  • FrankTX24 May 31, 2008
    Thanks for the help. actually just decided to replace the TV for $220. It would have cost 100 or more to fix so figured it be easier to buy a replacement, these tvs are pretty cheap now. Craigslist has them a dime a dozen
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit. I guess it must be a high pitched squeal, actually...
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Manuel for trinitron 36 inch tv
Owners manuals are available for download free at esupport.sony.com. Service manuals are available for a price at www.servicemanuals.net, either paper or download.
May 24, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony trinitron srs wega 36 inch colour is going blue gone already is it worth fixing?
hello eightythreem!
some pro's and contra's...
Trinitron tubes are the best ever built picture tubes - long life, best contrast and sharpness, brilliant colors, etc thou u never get with any modern lcd screen. otherwise the big form factor is uncompareable with todays thin screens. also the brand itself and in your case the wega model is a name on its own high standard. anyway i would recommend you to let your tv check by a local service cause it sounds like a electronical problem - let them tell you how much aproximately fixing will count - before they repair it - so you still can decide is it worth or not. hope to helped a bit.
regards
Feb 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 36" Trinitron Problem
Good day.
There may have been some problem in the horiontal transistor. Also, Check for the zener diode that controls the supply going to the flyback. It might got busted due to the sudden supply surge.
chris
Mar 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron wega 36 inch
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nov 11, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony 36' trinitron no picture but sound
I don't think it's your picture tube, but it may be a problem in your high voltage power supply. If there is no anode voltage then there is no raster (light from the screen) or picture. If it is your high voltage section the you may want to think about taking the set to a shop because of the danger of electrical shock.
Sep 21, 2007 | Sony KV-36XBR400 36" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
715 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
