Question about Vizio L32 32 in. LCD HDTV
Can't get my RCA DVD player to work with my new 32 inch VISIO TV. it will come on but won't play
  • 99 Answers
SOURCE: Visio 32 inch LCD TV
First of all we need to know if you are working off of an audio system or off of the tv speakers and its built in amp. Answer this and I will get back to you.
Posted on Jan 27, 2008
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
Neoklassic1
  • 70 Answers
SOURCE: Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Posted on Oct 19, 2008
  • 44 Answers
SOURCE: New vizeo 32" LCD TV -- black and white?
check to make sure that both are tuned to the same chanell.
Lou Margolis
Allied Electronics
loumargo@verizon.net
Posted on Dec 16, 2008
pra0099
  • 153 Answers
SOURCE: My LG 32 inch tv will not pik up signal from DVD
check using other player ..
to conform wether the tv line is clear...
Posted on Sep 28, 2009
TH BUTTONS ON MY RCA 32 INCH TV WON'T WORK
If all do not respond the set likely has a keyboard lock feature---look to the owner manual and read it carefully.
Dec 09, 2012 | RCA L32WD12 32 in. LCD HDTV
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Memorex MVD2016 DVD Player
Rca 32 inch has picture but no audio dvd player works fine when plugged in.
Hello
If your TV has audio and video when connected to DVD player, its sound filtering circutary in RF[Radio Frequency] stage is in trouble. You yoursef cannot detect and repair it. You must get the service of an experienced service personal. It needs skill, ability to follow the schamatic diagram, and more patience.
If there is no sound when DVD player connected, the speaker of your TV has in trouble. It can be replaced by you, after unpluging your TV from mains socket, open its back cover, screw out it from its position and go for a similar type and impedence. Just refit the new and give the 2 connections. That is all. Ok.
Oct 21, 2010 | RCA F32649 32" TV
Vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
Jan 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Jun 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Vizio L32 32 in. LCD HDTV Logo
101 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
