Question about Magic Chef 31000 Gas Kitchen Range
The oven does not light but the electronic igniter does glow.
  • 5,911 Answers
As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. It can be a control board issue, but is usually a weak or failed oven igniter.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
If you have any questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Posted on Aug 04, 2010
Oven shut off and won't re-light
defective glow bar or bad safty valve. But if the glow bar does not light at all, most likely it will be a bad glow bar
Jul 09, 2014 | Summit WNM4307KW 36" Freestanding Gas...
My hotpoint. Has burner activity. The electronic oven will not light, makes no sound when the temp knob is depressed, nor with a match under the burner will it light. Makes no sound through trying each...
Ok
Is your igniter glowing when oven turned on.Look for bright orange glow near burner.If yes ,and no ignition,then igniter is weak and needs replacing.No glow at all,then a voltage test at the igniter needs to be done to see if it might be thermostat problem. Very common for igniters to go.Most likely cause.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
How do i turn the pilot light off. I want to use a bug fogger in my apartment and i want to temporarily turn off the pilot on my stove
This model should have pilotless electronic ignition.If you hear clicking when you light the burners , it is electronic,. Also , open broiler drawer and turn on oven .After a few seconds do you see a glow start?Thats your electronic oven igniter confirming you have no pilot.
Was this helpful?
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Lights once then not again
    Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
    This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
    Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Top burners work, oven not getting gas electronic ignition comes
    The electronic ignition system (a ceramic plate that glows red) lets some power pass through to allow the gas to flwo when it has reached lighting temperature. The ceramic lighter needs replacing. Either that or the general electronic in the stove are shot.
    Mar 11, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Kenmore Oven not working
    Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
    May 27, 2008 | Ovens
    GE Oven does not light - no gas smell and no electronic ignition clicking sound
    It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
    If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
    Nov 19, 2007 | GE JGRP17 Gas Single Oven
    Magic Chef 31000 Gas Kitchen Range Logo
    98 people viewed this question
    Top Magic Chef Kitchen Ranges Experts
    Paul Carew
    Sal De
    Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
