Question about HP LaserJet 1020 Printer
HP Laser jet 1020 printer. The local print spooler service is not working. What is the problem and how do I fix it?
    President:
  • 2,571 Answers
Google print spooler problems, there is alot of advice on google.
You need to go into services and turn it on, but you may need to alter some registry settings
Posted on Aug 04, 2010
I can not print on my HP Laserjet 1020. It first asks that I install a printer before printing but when I try to install the printer it says that the local print spooler service is not running. It then...
try to restart the spooler system.
to do it:
1) click start
2) on the search box type Services and hit the enter key
3) on the windows that appear after you hit enter. Find priter spooler
4) once you find it. double click it.
5) on that window. and make sure that the startup type is automatic and finally click start.
Note: if the spooler service is already running stop it and restarted back in.
hope this helps
Jan 18, 2011 | HP LaserJet 1020 Printer
WHAT WILL I GONNA DO WHEN MY PRINTER SPOOLER IS
click on start->run and type services.msc
and then look for print spooler service.just click on start service.if it is already started.then stop it and start it again and then restart your computer and it will be fine
Jul 27, 2010 | HP LaserJet 1020 Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
Hello, my laser jet printer is not connecting, msg when attempting to print says "Windows cannot open add printer. The local print spooler is not running, please start the spooler or restart machine." I...
Start by removing the printer driver(s). Check several times, as some printers hide in lots of places. Once the printer/driver(s) are all gone, try a new installation.
Nov 07, 2009 | HP LaserJet 1020 Printer
I have a HP Laser jet 1020. I am getting a spooler error / spooler must shut down on start up. I have downloaded software including Driver Robot that is suppose to update drivers etc. to no avail Last...
I believe you have installed the driver from the CD (you did not mention the operating system). Hence I recommend to install the UPD (universal Printer Driver) PCL6 for your machine.
Remember to disconnect the computer and connect the printer only when the installation wizard asks you to do so.
To download the driver go to http://www.hp.com/go/upd
This will solve the spooler issue, also follow these instructions
Start>run>services.msc>print spooler>right click, stop and then start again
Rgds,
Nikhil
Jul 13, 2009 | HP LaserJet 1020 Printer
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
Printer Spooler Service not working
Reinstalling drivers usually fix this problem.
Reinstall drivers with printer connection cable unplugger, either using driver CD or download from the link below.
HP LaserJet 1020 Printer series - Download drivers
May 10, 2009 | HP LaserJet 1020 Printer
Printing Labels
Sorry loose plug. All fixed!
Jan 06, 2009 | HP LaserJet 1020 Printer
1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Jul 09, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
217 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
