Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Its a DD601 Model and it has F4 in the window and stops working after 60 mins wash?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F4 in your fisher & Paykel dishwasher occurs when no temperature increase has been detected for 2hrs while the unit heating element is turned on. The issue seems to be with a bad element, bad wiring harness and/or the control board itself has gone bad. To start with you’ll have to check the element, temperature sensor and if they appear fine then check the electronic control as this is responsible for supplying the power to the element. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 04, 2010
Why does my Whirlpool Cabrio HE Washing Machine smells like urines and how can I fix it?
try using some baking soda water in it ,that works for smells sometimes better than bleach
Oct 25, 2015 | Whirlpool Washing Machines
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
F&P DD601 TOP DRAWER IN ALARM F3 , ANY IDEAS?
F3 alarm in F&P DD601 is linked to water temperature. If you are using cold water supply connection, then it is likely the heater unit or temperature sensor has gone faulty. If you are using hot water supply direct then the inlet water temperature is exceeding recommended range of approx 65deg C. DD601 is a fairly old unit and not sure if you can still get some parts.
Nov 05, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykell DD601 V2 Top Drawer Overflowing
I suggest pressing the keylock and power button together, hold for 5 secs, the display will change orange, the display should read HP if it says LP, press the start button to make display read HP.Then press power button to store. You will need to manually removed the water from the machine before restarting
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
103 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
