Question about Microwave Ovens
I have a GE microwave. The display panel says F3 and the microwave beeps and will not run. If I unplug it it will then work if you use it right away. But then it will display F3 again and beep and not work unless you unplug it again. What does F3 and the beeps mean?
  • Microwave Ovens Master
  • 9,086 Answers
F3 means that your keypad is shorting.
If you'd like to have us fix it for you, we do that for $39.95 plus parts. We repair them for customers nationwide.
Or if you want to do it yourself, please contact me directly and I'll give you details on parts and procedure.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is beeping with F3
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
F3 occurs if the controller detects a key shorted for more than 60 seconds. Luckily, on this model, the "keypanel" as it's called is available as a separate part. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering the model number here: http://tinyurl.com/gv383 The "keypanel" is shown as reference number 44 on that exploded view.
May 22, 2007 | GE JES1039 Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
Microwave Ovens Logo
281 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
