Question about Hiro (H50113) Analog Modem
I can't get the HIRO H50113 to give me the caller ID from my fax server on Windows 2008 SBS. Is there a command sequence I have to issue to the modem to get it to send the caller ID to the fax server
3 Suggested Answers
Thod
  • 4 Answers
SOURCE: USB modem HiRo model H50113 will not complete phone connection
Yes you're right! What you have to do is:
  1. Right click My Network Places
  2. Select Properties
  3. Select the Advanced menu
  4. Uncheck "Operated-Assisted Dialing"
Posted on Feb 03, 2008
davecon
  • 85 Answers
SOURCE: model H50113, xandros linux compatibility
yes i think it is compatible with linux os's
Posted on Apr 25, 2008
How to reset Windows SBS administrator password?
Reset Windows SBS administrator password seems to be a tough thing. But don't need to be panic. There are two effective methods for you to reset Windows SBS admin password. The first method may be a little easier than the second one.
Method one: Reset Windows SBS 2011 Password with Windows Password Genius
1. Download iSunshare Windows Password Genius, launch it and insert USB or DVD/CD into your accessible computer.
2. Create a Windows SBS 2011(Windows Small Business Server) password reset disk by USB or DVD/CD. Select right removable device and click "Begin burning" button
3. Insert the USB or DVD/CD into your locked Windows SBS, set Windows SBS boot from USB or DVD/CD.
4. Choose Windows SBS 2011 and user account, Click "Reset password", then "Reboot" computer after successfully reset password to blank
Method two: Reset Windows SBS 2011 Password with Start Disk
1. Restart your Windows SBS 2011 with the installation CD or any USB/DVD you can boot from and get access to the HDD drive.
2. Booted from SBS 2011 media, select Next
3. Select Repair your computer
4. Select your partitions and installed Windows version and click Next
5. Select command prompt
6. Change directory to the access the system 32 directory. Then your original C:drive is changed to D: or E: depending on the number of drive and partitions you have on that system.
7. Rename Utilman.exe to Utilman.old and copy cmd.exe to Utilman.exe, exit and reboot
After the reboot select the Ease of access icon
8. You will get a command prompt and use net user admin user password to change the password
At the user logon screen, press a combination of Windows KEY+U, then the CMD.exe will appear. Type net user "Username""new password"
After you changed the password, exit the command prompt and login in with the new password. Don't forget to change the Utilman.old back to Utilman.exe. It could be that you will need to reboot with your media to change the Utilman back.
Aug 09, 2013 | Microsoft Windows Small Business Server...
Disk is damaged
Download the driver from here, to another computer, then copy to a thumbdrive, move to the other computer:
http://www.hiroinc.com/drivers/H50113/
Oct 23, 2012 | Hiro (H50113) Analog Modem
Forgot the password.What is the default password. is there a way to reset password without erasing config
You can create a Windows password reset disk to reset your lost or forgotten Windows password, i have created one with the tool Windows Password Breaker and reset my administrator password successfully.
Dec 16, 2010 | Hiro (H50113) Analog Modem
Hiro USB modem, vista cannot detect. It is in
I THINK THE PROBLEM IS IT IS ANALOG AND WE LIVE IN A DIGITAL WORLD, MEANING IT PROBABLY ISN'T COMPATIBLE.
Jan 09, 2010 | Hiro (H50113) Analog Modem
Usb modem driver
there are other peripherals that conflicts with this modem. try to plug this usb modem alone without other peripherals connected and check. if the problem persists then the modem itself has a problem
Nov 05, 2009 | Hiro (H50113) Analog Modem
H50113 modem takes 1:30 to hang up regardless of message length
Ok, so I tried the modem on a new Dell (C2D laptop), WinXp, USB 2.0, with the XP drivers supplied from the CD, and I still get the same result. Sadly, this is either a defective modem, or yet another driver issue that hasn't been resolved. In any case, I ended up downloading a program called PhoneTray Free which is a Caller ID/Telemarketer Zapper program. This works quite nicely with the FaxTalk software supplied with the Hiro modem. Basically, I can eliminate a number of the 1:30 messages by having the PhoneTray software ZAP the calls on the first ring automatically if they are a blacklisted number. Hopefully, this helps.
Regards
Feb 03, 2009 | Hiro (H50113) Analog Modem
Model H50113, xandros linux compatibility
Apr 09, 2008 | Hiro (H50113) Analog Modem
Jan 30, 2008 | Hiro V.92 56K AGERE Chipset PCI Fax Voice...
Caller ID with the H50113
That modem has an Agere chipset. I think you should try a more recent driver. I believe the current one is 2.1.84.0 (November 2007). The driver .INF files allow the modem responses to be properly interpreted. If you can't find a recent version on Hiro's site, try another vendor's site. Encore USA also makes modems with the Agere chipset. After installing the driver you will want to add "AT+VCID=1" as an advanced setup string for the modem (via control panel phone & modem options applet).
Nov 26, 2007 | Hiro (H50113) Analog Modem
Hiro (H50113) Analog Modem Logo
Top Hiro Computers & Internet Experts
Prashant M
Prashant M
none
Are you a Hiro Computer and Internet Expert? Answer questions, earn points and help others
