Question about Cell Phones
My iPhone won't charge. It's plugged in to my computer like I do everyday, but what little info I can get is telling me that I need to plug it in to get it charged. It's dead flat now and not charging up.
  • 268 Answers
Absolutely, dead flat. Need to plug in to wall charger.
Posted on Aug 04, 2010
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Bought my iphone 5 and am unable to charge using both the plug and computer. however am able to charge using the iphone 4 plug. please help!
Before you can charge your iPhone on the computer, your computer needs to install the drivers for it. You might have to reinstall the drivers for it. A good way to check if the drivers are incorrectly installed is to see if iTunes detects it. Try updating your iTunes since the old version of iTunes won't work with ios6 and all iPhone 5 are shipped with ios6
Oct 10, 2012 | Apple iPhone Smartphone
Iphone shuts off and won't turn back on what do i do?
You might try holding down the power and home buttons at the same time. Wait until you see the silver apple. Thats what I did when mine wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut down your iphone...and leave it there for how ever long it takes to charge...(to be able to use it again is about 30 minutes)depends on your energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do not plug it into your iPhone. Then press and hold the home button on your phone while conecting the iPhone cord into your iPhone continue to hold down the home button. Then click restore in iTunes
Feb 15, 2012 | Apple iPhone 4 Black Smartphone
How do I pair a RocketScience Tracer bluetooth?
    • 1How to Pair a Bluetooth Device With an iPhone On the iPhone, click on the "Settings" icon. It looks like a gear. Then press on the "General" button. Select "Bluetooth" and then "Turn Bluetooth On." The phone is now ready to be connected to the Bluetooth device.
    • 2 Connect the iPhone Bluetooth travel cable that comes with the iPhone-approved Bluetooth device into the USB 2.0 port on the computer. Do not plug it into the USB port on the keyboard.
    • 3 Connect the iPhone to the other end of the cable. The cable goes into the data connection slot on the bottom of the iPhone. There is another slot on the top of the cable into which the Bluetooth device should be plugged in.
    • 4 Wait while the computer loads to recognize there is something plugged into it. Either a screen will pop up or an icon will appear on the desktop to let you know that the computer is recognizing there is a iPhone plugged into it.
    • 5 Let the Bluetooth device charge with the iPhone for about one hour. You can tell when the device is fully charged by viewing the status light on the device. It will be an amber color until it charges completely. Once the charge completes, it will turn green.
    • 6 Remove the Bluetooth device and the iPhone from the cable that is plugged into the computer's USB port. Push the button on the top of the Bluetooth device. This allows the calls to now go through the Bluetooth device instead of straight to the iPhone.
Jan 02, 2012 | Apple iPhone 3G
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
I can't charge iPhone, I got power surge warrning on my computer
hello friend,
maybe your cable of charging is nit genuine,
if warning displays in your phone then there is the problem in cable
and if the error displays in computer then the problem should be in battery or main board
Apr 22, 2010 | Apple iPhone Smartphone
I plugged my iphone to the computer but it wont charge or sync
Try turning it off and then back on, if turning it on and off doesn't work, restoring it might work. Also try to remove the SIM card and put it back into the phone. I recommend simply exchanging the phone at the Apple store if it is still under warranty. Click on the links below to see other soultions for the charge and sync iphone problem
http://discussions.apple.com/thread.jspa?threadID=1392386
http://support.apple.com/kb/HT1737 (For PC users)
http://support.apple.com/kb/TS1410 (For Mac Computers)
Jan 06, 2010 | Cell Phones
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
My iphone wont charge
I had this exact problem too - same as the first two posts anyway.
It seems to be just a software issue and was easily resolved for me with a full power off and reboot. Here is how to do that safely.
Plug in the phone using the wall socket charger, leave it for a few hours to get a charge (i know it doesn't look like its charging). Later, press the on/off button. The battery icon appears with just a thin red line. Let it go back to black. Then press the the on/off button and the menu button simultaneously for about 8 seconds. A red button should appear on the screen with a question asking if you want to power off the phone. Say yes. (I think it was a slide bar, but can't remember now.) Wait a few secs while the phone powers off. Then remove the power plug from the phone. Now reinsert the power plug. After a few (worrying) seconds of nothing, a white Apple logo appears in the middle of the screen, a few more seconds and the iphone main menu appears. No data has been lost, no settings are altered, and best of all, the battery shows a full charge and seems to be back to normal again.
Nov 23, 2007 | Apple iPhone Smartphone
Cell Phones Logo
75 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
