Question about Conair FX944GT Phone
The message, repeat time set, play/skip, greetings and on/ off does not work. The basic and the speaker phone works?
How do i retrieve messages when out of town, from my v-tech 5.8 & can i use my cell phone to do this ?
If I remember correctly you can remotely connect to your answering machine.
When you call the phone and it greets you (assuming you haven't changed the code) press 19 to get it going.
You should then begin to hear your messages. After you get past the 19 part (options are as follows)
1 ) Plays all messages 2 ) Plays only new messages 3 ) (During playback) Deletes the current message 33 ) Deletes ALL OLD messages 4 ) Repeats current message 5 ) Stop 5 ) (While no message being played) Lists Available Commands 6 ) Skips to next message 7 ) (While no message being played) Record new greeting 8 ) Hang up 0 ) Turn Answering Machine on/off
Jun 29, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
How do I access my messages when I am out of town. I have a Panasonic DECT 6.0 Thank you. ginny
Call your phone while you're away, and when your message starts to play enter your remote code. After that, you use the keypad on the phone to control message playback, record a new greeting, etc.
"DECT 6.0" is a generic term for the cordless phone technology, and not your phone model number. You'd find that on a label on the back or bottom of the base unit. Without a specific model I can't look for a manual and give details, but if you have the model listed you can download the manual from Panasonic here. It gives all the steps to set up your remote code and the commands to use. If you have a different model phone you can look for your manual at Panasonic's support page.
For the model listed above, the default remote code is 111. The list of remote commands is
Key Remote command
{1} Repeat message
(during playback)*1
{2} Skip message (during
playback)
{4} Play new messages
{5} Play all messages
{6} Play greeting message
{7} Record greeting
message
{9} Stop recording
Stop playback*2
Start voice guidance*3
{0} Turn answering system
off
{*}{4} Erase message
currently playing
{*}{5} Erase all messages
{*}{6} Erase greeting
message (during
greeting message
playback)
{*}{#} End remote operation
(or hang up)
Maybe this list works for your phone too.
May 31, 2011 | Panasonic KX-TG1033S Cordless Phone
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
How do you set the answering machine or voice mail on this phone?
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: http://telephones.att.com/documents/product_Product/219/UserManual/1982/1855_manual_bkm.pdf which may or may not work.)
Oct 29, 2010 | AT&T 1855 Phone
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
message
1 {GREETING REC}
clearly about 20 cm (8 inches) away
from the MIC.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
message
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
I have a panasonic Cordless phone and can't remember how to remote access it?
Using the answering system
remotely
Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code (page 59).
LThe unit plays back new messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
necessary.
4 When finished, hang up.
Note:
LYou can ignore the voice guidance and
control the unit using remote commands
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
Note:
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 3 minutes of recording time is
available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
you.
Key Remote command
{1} Repeat message (during
playback)*1
playback)
{7} Recording a greeting
message
You can download the full manual at
http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
Please make sure to rate this solution. Thanks.
Jul 23, 2009 | Panasonic KX-TG5776S Cordless Phone
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
* For the Repeat a Message function, press 0 then 1 within about four seconds to
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
4) Enter a command within 15 seconds, each command there after must be entered within 2
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Conair FX944GT Phone Logo
19 people viewed this question
Top Conair Lands Phones Experts
k24674
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
