WASHING MACHINE WILL NOT SPIN IN SPIN CYCLE MODEL-WJSR2070B 7CYCLE 2WASH SPIN COMBO
Disconnect power cord for 1 minute. Open and close lid seven times. This resets computer.
Posted on Oct 21, 2008
My washer will not spin after a heavy load of towles????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 02, 2010 | GE WJSR2070B Top Load Washer
Problem with knocking noise during the spin cycle? What is the cause?
Inspect the suspension shock absorbers. They can be broken, out of oil, or the knuckles broken where they mount to the machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | GE WJSR2070B Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool top loading washer won't go into the spin cycle, what is wrong ?
There is an excellent video on washing machine repair on utube. The most common problem is a bad lid switch. probably the next most common problem is the water level switch. It's not likely to be the timer, they tell me they almost never go bad, and to prove it, they don't stock them. The utube video shows you how to open the machine and get access to check parts and repair the problem.
Nov 14, 2009 | GE WJSR2070B Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Spin cycle not working
hi
if it is not draining it won't spin right,if it is empting out ok then it can be the solenoid if that model has one, if it has belts check that they are not loose
cheers grant
Nov 11, 2008 | Whirlpool LSN1000LW Top Load Washer
GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
