Question about Timex IRONKIDS 70491 wristwatch
How do you put the date in the watch? - Timex IRONKIDS 70491 wristwatch
Mondaine Retro automatic day date are not aligned. Date also skips occasionally
Hello Tom Bott,
The Mondaines I have seen a big, bold,
beautiful watches...
Sorry...!!
If it is INDEED NEW... ("The other week")..
I would take it IMMEDIATELY back & get another.
Day-Date watches can INDEED be damaged by
moving the DAY/DATE inside specific times
around midnight...
Most watches
can handle the ABUSE but some
cannot... (keep in mind it could actually be defective).
The watch will not heal itself... and unless you failed to put the stem/winder all the way home... SOMETHING is tragically WRONG with your watch.
My BEST ADVICE... exchange it (now).
Mondaine Men Swiss Railways Giant Watch A6603032811SBB
Carnac the Magnificent
May 04, 2017 | Watches
Hello please help, I wish to know what year Rolex Oyster Perpetual Lady Date model 6519 was Manufactured. Thank you in advance.
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
http://www.bgrayjewelers.com/rolex_information.htm
Jun 03, 2011 | Watches
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
I cant figure out how to set time and date
Hi idarr,
Please follow these steps to set the time and date of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Mar 13, 2011 | Armitron 40/8125BLK Digital Sport Watch
I need set the date of my Armitron watch Thank you
Hi diazlieter,
To set the date of your Armitron watch, please do the following.
Hope it helps.
Feb 14, 2011 | Armitron 40/8125BLK Digital Sport Watch
Watch instructions for Armitron m721 (49/1009 GP) need to set time and date
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
Hope it helps.
Jan 05, 2011 | Armitron 40/8125BLK Digital Sport Watch
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
Hope it helps.
Dec 05, 2010 | Armitron 40/8125BLK Digital Sport Watch
I have a guess steel watch , and i have set my date and time right , but i cant put the day right , so monday or tuesdag for example.
Advance the watch time 24 hours to change to the next day. keep turning until it reaches the corect day of the week, then reset the correct time and date.
Nov 14, 2010 | Guess Watches
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Set date on skagen 496sgsc
I used to sell Skagen watches,don't know excatly which watch you have . I even went to their web site and couldn't find it. Most Skagens ( unless they are a chronograph with the three curcles on the dial) works like this: Your watch stem has 3 differant settings #1 all the way in #2 half way out , and #3 all the way out . To set the time you pull the stem all the way out and adjust the time. To set the date,pull the stem all the way out and turn untill the date changes ( this will make sure you have it on am-pm correctly) then put the hands at 6 o'clock. Put the stem all the way back in, then pull the stem half-way out. Start with the stem all the way in and slowly pull it out and you will feel the "click" when it is half-way out. MAKE SURE YOU HANDS ARE NOT BETWEEN 9 O'CLOCK AND 3 O'CLOCK, OR YOU WILL BREAK THE AUTOMATC DATE SETTING GEAR!!!!! Then either turn the stem clock-wise , or counter clock-wise , one of the two ways will set your date.
Oct 27, 2008 | Skagen Watches
Timex IRONKIDS 70491 wristwatch Logo
43 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
