Hello samsung sp61l6hx rear pro.picture and audio crisp and clear for 15 to 25 mins,after this time tv loses picture.[blank screen]audio still works though.turn tv off and on again and picture returns,but for a shorter period of time. please help. regards tom...
  • 121 Answers
Try to resolder your vertical output IC thats a commen problem when the tv does that
Posted on Apr 26, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a Samsung rear projection tv, the picture is faded and the colors are not crisp or clean cannot watch it like this what do you think the problem is?
If this is a CRT-type rear-projection TV, the CRT coolant fluid is probably broken down. It's supposed to be clear, but after a long period of TV operation, it turns a yellow-brown color. If you unplug the TV and remove the back, you can look into the tops of the three picture tubes. They should be a clear red, green or blue color, with no yellow-brown tint.
CRT coolant can be changed, but you need to be very good at mechanical work to do it. Besides the safety considerations (picture tubes and other parts may carry a high voltage charge even when the set is unplugged), spilling broken-down coolant on electronics is usually disastrous, so you have to be very careful.
LCD panels used in projector applications may lose contrast if they are overheated (this can be caused by failure to keep the vents clean as recommended in the owner's manual).
You would have to provide your set's model number to get more specific information.
Oct 27, 2010 | Samsung Televison & Video
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung 40 inch LCD LNS4092D No Picture
You need to check the back light is still on when the screen is blank (check through the back).
If the back light is on, need to change the Powwer Board.
but,
no back light, need to change the inverter.
Feb 06, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung rear pro..
ya, sounds like a bad light engine, but first i would check all connectors to make sure they are seated correctly.
this could cost you alot of money!!!
you need to call 1800samsung
if you talk to them and sound upset they may just fix it or replace it.
good luck
Apr 29, 2008 | Televison & Video
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
