Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven won't light. Electric ignitor is glowing, but the oven won't light and I can smell gas.
Electric ignitor is glowing, butthe oven won't light I do not smell gas
Posted on Aug 13, 2010
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
I have a GE True Temp XL44 oven the stove burners work fine but the oven will not light. When I turn it on the oven, I do not smell any gas. What is the problem and how do I fix it?
could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
Feb 13, 2011 | GE Ovens
My Amanda gas oven Model no. AGS781WW is not heating up in the oven, nor does the broiler come on. The electronic ignition glows, I don't smell any gas in the oven. The cooktop comes on fine.
even if the ignitor glows it may not be getting hot enough to light the gas. if it does not get hot enough the gas valve should not open. try changing the ignitor, usually 30 - 60 dollars.
Jun 21, 2010 | Ovens
Oven ignitor glows bright red, but oven will not light. No smell of gas.
our ignitor glowed but still was not working right. it has to get to a certain temp before the gas valve will open. try changing it out. fairly inexpensive.
Jun 19, 2010 | Magic Chef 9122 Gas Single Oven
Igniter comes on but gas won't light
It should glow almost a bright white. If its just an orange glow then replace the ignitor. Its probably just weak. If its weak it will not allow enough current to flow through it to open the gas valve. Good luck _MJ_
Mar 24, 2010 | Frigidaire FEB27S5A Electric Single Oven
The oven wont light. Panel light comes on and
Attach a amp meter to the ignitor wire. If you read 3 amps or less,replace the ignitor. 3 amps or more replace the gas valve.
Sep 06, 2009 | Ovens
Gas stove the burners are working but the oven is
Hi, The ignitor in the oven does not spark. It glows and has to pull enough amps to open the safety gas valve. The most common issue with these ovens is the ignitor. It can glow red but not be strong enough to open the valve. Remove the bottom panel in the oven and you can see the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Ovens
Wall oven will not light
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Mar 28, 2009 | Maytag 24" Built-In Single Electric Wall...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
234 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
