Question about Victor Power On Board 1500 Watt Power Inverter
For a long while the little fan made all kinds of noise on my 750 watt Maxx sst VECTOR inverter. Now the blades don't turn at all and heats up. Can this fan be replaced?? how much cost? how and where IrmaWillTravel@Gmail.com
  • 12,061 Answers
Yes this fan can be replaced real easy, it is most likely a 12Volt DC fan, so any 12 V DC fan that will fit, will be OK. If it is a 120V AC, again simply obtain the same similar type, and replace it no worries.
However I wonder if the reason the fan isn't working is because there is a fault with the unit? Of course if it is working OK, 100% then obviously it is just the Fan, and replacement will be OK, the fans are marked, so you can get a similar/same one, but it doesn't really matter as related if it fits it will be OK.you can get one from say eBay, Craigslist, or by Goggling etc. They are inexpensive. maybe US$20.00?
Posted on Aug 05, 2010
Do I need to put a inline fuse or does the vector sst 1200 have a fuse or breaker in it
It probably does, but an in-line fuse is still the safest way to go, connected as close as possible to the voltage source as possible. The internal overcurrent protection device (aka, fuse or breaker) in the inverter will prevent the DEVICE from melting if it malfunctions. An in-line fuse will protect EVERYTHING if the WIRING malfunctions.
May 05, 2014 | Vector ® Maxx SST 1200 - watt Power...
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Feb 05, 2011 | Vector VEC024B MAXX SST Power Inverter
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Dec 22, 2010 | Vector VEC024B MAXX SST Power Inverter
Will not turn on
sounds to me like there is a dead short somewhere in the system, I would take it to an electrical appliance repair shop and they can fix it. If there are none in your town then look on the internet for one in your state so you won't have to send it very far to get it fixed.
Jul 14, 2010 | Vector MAXX SST 500 Watt / 1000 Peak Watt...
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Victor Power On Board 1500 Watt Power Inverter Logo
23 people viewed this question
Top Victor Electronics - Others Experts
Marvin
Marvin
Are you a Victor Electronics - Other Expert? Answer questions, earn points and help others
